• 09.10.2026, 06:53
Top_Nurse
Aquaero - DDC question
Wednesday, May 11th 2005, 1:00am
Can the DDC pump with the RPM sensing, being sold by A-C, be controlled by the Aquaero?
Mr_modnaR
Re: Aquaero - DDC question
Wednesday, May 11th 2005, 1:11am
Not sure on that one. It looks like the pump is controlled as a fan; i.e. with 12V, 0V and Signal wires. So technically you could wire it up to run off one of the fan connectors on the aquaero, it just depends how much power it requires, and whether that exceeds the limit of one of the connections on the aquaero.
Wednesday, May 11th 2005, 1:26am
I think that is not a good idea because the maximum output of a fan channel should not exceed 5W.
Top_Nurse
Wednesday, May 11th 2005, 3:12am
Hmmm... What do you think of hooking it up to the Multi-Switch and controlling it from there?
Wednesday, May 11th 2005, 4:07pm
As far as i know multiswitch has no adjustable output. On and off - that's all ;)
Mr_modnaR
Wednesday, May 11th 2005, 5:00pm
Quoted
Cheers shoggy! Didn't think it was possible.
Is the DDC pump D.C. powered though? Because you would be able to control then, surely? If not by the Aquaero, then by a fanbus that handles whatever power it requires?
Dragonclaw
Wednesday, May 11th 2005, 7:42pm
http://forum.aqua-computer.de/index.php?…&threadID=89442
www.people.freenet.de/Shorty1967/laing.pdf
here you'll find a solution to controle the ddc, maybe a little bit better then a normal fanbus ;)
Top_Nurse
Thursday, May 12th 2005, 8:40am
Thank You Dragonclaw :)
The German will take a while to interpet, but the schematic was great....no language barrier there. ;D
