• 13.11.2026, 22:51
edboswell
somethings wrong
Sunday, May 15th 2005, 5:35pm
i don't know what wrong with my water cooling the pump simply wont pump any water round. Is there any possiblity that i have pushed the hose's too much into the pump or something --
one thing i have to check - the pump is in default position water is pushed out the top?
any help would be greatly appreichiated
Thanks Ed
ps the reservoir is at the top - feeding water into the pump,
Reservoir --> pump --> cpu --> gpu --> 1800 --> Reservoir
Infiltraitor
Re: somethings wrong
Sunday, May 15th 2005, 5:42pm
What pump are you using?
edboswell
Sunday, May 15th 2005, 5:47pm
its a ehem 1048 but dont worry now i have it working - the 1800 had a lot of air in and i had to do was move it - the air then rushed out and it started to work :D
