• 22.11.2026, 22:38
edboswell
Aqua Lighting LED mod for the Aquatube
Sunday, May 15th 2005, 1:24pm
hi is it just me or is the Aqua Lighting LED mod for the Aquatube very loose inside? It fits in perfectly but theres nothing to push in to make sure its in place... you need to apply very little (if any) pressure to get it out. Am i missing something or should i use some sort of selotape etc.??
Thanks Ed
http://www.aqua-computer.de/prodimg/nd_p…t_unten_500.jpg
fabelmann
Re: Aqua Lighting LED mod for the Aquatube
Sunday, May 15th 2005, 1:57pm
you are right. i personally, fixed the problem with a littlebit glue, because while the first try with tape, the led has loosen himself, because of the heat
Top_Nurse
Sunday, May 15th 2005, 2:01pm
A dab of clear RTV also works well. :)
Mr_modnaR
Sunday, May 15th 2005, 2:18pm
sort of on the same subject:
how did everyone else tighten the plexi inserts into the aquatube? cos there's nothing on it to help you grip it, as far as i can see..
Top_Nurse
Sunday, May 15th 2005, 2:28pm
latex or rubber gloves
edboswell
Sunday, May 15th 2005, 2:40pm
i just used my hands yer there is no other way unless you use plyers but i think its should be secure enough by just hand tightening it
Mr_modnaR
Sunday, May 15th 2005, 2:58pm
excellent, cheers guys
maybe they should have made them with a hexagonal hole, like the metal bungs?
edboswell
Sunday, May 15th 2005, 3:08pm
yer would have been better that way
Top_Nurse
Sunday, May 15th 2005, 9:55pm
Ever tried to put a round peg in a square hole?
Mr_modnaR
Sunday, May 15th 2005, 10:28pm
yes and it's fine if you make the sides of the square equal the diameter of the round peg :P
Top_Nurse
Sunday, May 15th 2005, 10:39pm
True, but then the LED light would probably be going in places you didn't intend it to...
Mr_modnaR
Sunday, May 15th 2005, 10:44pm
why?
if you make the hole so it's a tight fit, as they are now, there shouldn't be any problems. you can always use:
Quoted
A dab of clear RTV
:P
