• 20.11.2026, 12:13
leisan18
My AquaStream don't works very fine
Sunday, June 5th 2005, 6:07pm
Hi, I'm from Spain and and sorry for my bad english ;D. I buy the AquaStream pump last week and it mounts few dayts ago but it's doens't works properly. You can see the LR in this photo.
When I ignite the LR, the pump works but only for 4 seconds. In the control panel, the "status" led blinks all the time and also the error leds blinks.
But the pump do a strange noise when I ignite, you can hear in this link.
http://img300.echo.cx/my.php?image=pump4rz.swf
And you can see what do the control panel when I ignite the LR.
http://img293.echo.cx/my.php?image=controlpanel6tt.swf
Is seems that the vanes of the pump have something who obstructs them at the begining. Where it can be the problem?
Thanks.
leisan18
Re: My AquaStream don't works very fine
Sunday, June 5th 2005, 6:08pm
Sunday, June 5th 2005, 6:11pm
Hi and welcome to the forum :)
I would say the deaeration-mode is turned on. Just remove the jumper on the right side:
TrOuble
Sunday, June 5th 2005, 6:18pm
bienvenido a nuestro foro ;)
(sorry for my bad spanish)
Check the Jumper for deaeration-mode.
Just remove it to turn the mode off.
by the way :
looks pretty uncool ;)
greez
TrOuble
Ädit :
damn too slow ...
leisan18
Sunday, June 5th 2005, 6:29pm
Thanks so much, now works perfect, and the noise is 0 ;D. I quit the deoration jumper and it works.
TrOuble I see that, I will fix soon, but it works, is the most important. Thanks so much.
Salut.
leisan18
Sunday, June 5th 2005, 8:12pm
:-[ it has happened the worse thing, there is a fissure in the pump. Probably it appears why I put the screw too much hard and the housing of the pump will be broken.
There are to buy a housing/carcase? (i don't know this is ok, the translation of google get me this word). Because the pump is OK, but the problem there is in the carcase/housing of the pump.
Thanks.
Mr_modnaR
Sunday, June 5th 2005, 8:30pm
I think that part of the pump is moulded into the pimp itself, so unfortunately i think you need a new pump! :'(
you could try glueing it, but i don't think it's worth risking damaging your computer just to save a little money on a new pump.
you can buy the pump on its own:
Art.-Nr.93086
under 'ersatzteile' in the shop.
good luck if you try to glue it!!
Sunday, June 5th 2005, 8:37pm
The case is completly sealed. You will have to destroy the case to get your fingers on the electronic.
It should be nearly impossible to change the case. And I think getting the pure case is a problem too. I've never heard that you can get it as a sparepart.
leisan18
Sunday, June 5th 2005, 8:50pm
Ok, I will have to buy a new pump.
Thanks a lot.
