• 03.10.2026, 03:00
Mr_modnaR
twinplex size of bottom?
Tuesday, June 7th 2005, 12:36am
does anybody know how big the bottom contact plate is on the twinplex for ati cards?
here is a pic:
looks smaller than the normal one:
the reason i need to know is my ongoing, if a little pointless, quest to water cool a Via 1.2GHz cpu which is 35mmx35mm.
given the small size of the Via Epia motherboards (17cmx17cm!) i wanted to keep the thing as flat as possible, height wise, to make a nice low profile case for it. ;D
this is why i was looking at the twinplex for ati graphics cards, because the connectors come out of the sides.
obviously though, if the base isn't the full size of the water block, i don't really want to use it, unless anyone knows that it'd be safe?
Re: twinplex size of bottom?
Tuesday, June 7th 2005, 1:05am
The ATI twinplex has the same height as the normal Twinplex. The only difference is the cut-out on the bottom.
Mr_modnaR
Tuesday, June 7th 2005, 1:11am
Quoted
i meant that the connectors came out of the side!  ;D i.e. the overall height is lower.
can you get that top to fit the normal twinplex then?
cheers
Tuesday, June 7th 2005, 1:22am
Ahhh, you meant the plexi. I thought you were talking about the copper-bottom ::)
Yes, you can get this top as a sparepart.
Mr_modnaR
Tuesday, June 7th 2005, 1:29am
Quoted
i kinda was  :-[
i thought the ati twinplex was the only one with the holes on the side of the plexi, oops.
cheers once again Shoggy
edit: ps whereabouts in the shop are they? or can i just order a twinplex with one already on it?
Tuesday, June 7th 2005, 1:55am
The plexi-top ist not in the shop but you can get one if you ask.
In the shop below the infotext you have a dropdown menu. At "Deckel" you have to choose "Grafikkarte (+2,00 Euro)" and the picture should change to..
Mr_modnaR
Tuesday, June 7th 2005, 5:49pm
Excellent! cheers Shogg-meister!
