• 12.11.2026, 21:13
edboswell
m3 screws
Thursday, June 9th 2005, 9:46pm
hi does anyone know where to get some m3 screws from (for the 1800 rad.'s fans)... i really wanna just know how long i need them (exact size)
Thanks Ed
Mr_modnaR
Re: m3 screws
Thursday, June 9th 2005, 9:59pm
from rswww.com
goto: Mechanical, Fasteners/Fixing, Fasteners - Steel, Socket Screws, Hexagon Socket Screws, Cap Head, Zinc Plated Steel
 and then take your pick. you'll have to buy 100 of them unfortunately, but they'll always come in handy! there are other styles of machine screws that RS do, but these are the ones that are most like AC screws.  ;D
i think 12mm long m3 screws will do you, i think the threaded rivets on the APE rads accept about 8-10mm of thread. be careful you don't tighten them into the actual fins of the rad tho, at a push, you could use some washers.
edboswell
Re: m3 screws
Friday, June 10th 2005, 12:38am
ok thank you for that a lot... i think i will have to get longer screws than that you... i measured the papst 120 mm fan i have and that alone is 35mm - including the fan guard - the papst fans need the screw to go through the whole of it to get to the actual thread.
Infiltraitor
Re: m3 screws
Friday, June 10th 2005, 2:04am
You might have trouble finding anything longer than about 30mm for M3, unless you use M3 threaded rod with nuts & washers.
Are you going to fit a shroud to help eliminate dead spots?
Mr_modnaR
Re: m3 screws
Friday, June 10th 2005, 2:13am
Quoted
aah sorry, i forgot that these were for the fans!  :-[
RS do do some longer m3 screws:
http://rswww.com/cgi-bin/bv/browse/Modul…toid=-102607831
not as attractive, but 40mm should work!
edit: the other alternative would be to get some shorter srcews, and screw the fans to the rad thru just one of the two lugs at each corner, if you get my meaning? ie, not thru the full 35mm of the fan, just the 3mm or so of the surface touching the rad.
edboswell
Re: m3 screws
Friday, June 10th 2005, 2:40am
ok thanks for that i think ill go with just the 40 mm screws lol. Thanks for your help Ed
