• 02.10.2026, 03:09
vils
PrimoFlex
Wednesday, June 15th 2005, 3:40am
PrimoFlex is an excellent tubing but when trying to connect my TwinPlex gpu cooler it was to thick :(
It would have been nice if the web-shop had mentioned the max od of the tubes. The clearence while using 3/8" (ID) is'nt to big.
Now I either have to buy new tubing or a new gpu block.
All work and no play makes Jack a dull boy.
Re: PrimoFlex
Wednesday, June 15th 2005, 4:15pm
Every AC product is using plug n cool connectors for tubing with an outside diameter of 8mm and an inside diameter of 6mm.
vils
Re: PrimoFlex
Thursday, June 16th 2005, 4:19am
I orderd this block directly from the AC shop and chose "Anchluss-
Schlauchtullen 10mm" But since the distance between the hose barbs is so small they only seem to accept a wall thickness of around 1,5mm. It is this crucial part of information I would have liked to see at the web-shop.
/Vils
stu_allen
Re: PrimoFlex
Thursday, June 16th 2005, 10:47pm
Quoted from "vils"
/Vils
3/8 ID is 9.375mm - and the connectors you specified are for 10mm OD/8mm ID so its no wonder its a tight fit!
