• 30.11.2026, 23:59
THEdude
powering system
Monday, June 13th 2005, 4:07pm
Hello all,
I wanna have some information or thoughts from other people.
I have the problem that i can't have my aquaro on stand-by modus, no matter what i do.
Second problem is that when i have the aquaro powered to the system, i have to push the powerswitch a 40 times on and off (including the psu power switch) to powering up my system. When the aquero is not connected to the psu, my system turns on at once.
Because of these two things i'am thinking of RMA my aquaro to AC, unless someone has a clever idea. :P
Mr_modnaR
Re: powering system
Monday, June 13th 2005, 4:58pm
It sounds like you haven't set up the aquaero's relay connection correctly!
if you go to section 12 in the aquaero manual, you can find out which mode you need to have it in.
you may have to manually turn the relay connection on, which will connect the wire from your psu to the motherboard.
to do that, read the manual section 12.4
hope this helps! ;D
Re: powering system
Monday, June 13th 2005, 5:28pm
Are ypu using OS 2.03 and firmware 4.05e?
If not => update
THEdude
Re: powering system
Monday, June 13th 2005, 5:37pm
Nope, it runs on the delivered 3.99d. I'll update ASAP.
What is that OS 2.03?
x-stars
Re: powering system
Monday, June 13th 2005, 5:39pm
1. When you connect the Standby-Power -> did you change the Jumper-setting on the backside?
2. Do you use the Relais of the Ae? Parallel to the Power-Switch or integrated in the ATX-break? Did you change the Ae-Settings to the correct relais-mode?
Edit: OS2.03 is the first partt of the Aquaero-Update, the new firmware-version depends on a aquaero-os which must be flashed first ;).
THEdude
Re: powering system
Monday, June 13th 2005, 5:43pm
1.Yes.
2. Nope never used the relais, because i don't know where i could use it for. ;)
Re: powering system
Monday, June 13th 2005, 5:45pm
Your problems should be solved with an update. There are a few known bugs with the old software...
You can use my update guide but please note that this is not an official translation ;)
THEdude
Re: powering system
Monday, June 13th 2005, 7:35pm
I'am so happy with you Shoggy ;D
All my aquero problems are solved now! Including the stand-by modus does work now. And the aquero is finally in english, much better for me. ;)
Thank you guys!
THEdude
Re: powering system
Wednesday, June 29th 2005, 2:30am
Yesterday i plugged the USB kabel in and now the problem is back. ???
Are there any fixes released is the meantime?
THEdude
Re: powering system
Thursday, July 7th 2005, 6:49pm
It's starting to look like a phantom house. :-/
I can turn my system on by disconnecting and reconnecting the aquaero ubs cable on my motherbord.
I have latest firmware 4.06d and i still have problems with turning my system on.
Really desperate here... :-[
THEdude
Re: powering system
Thursday, July 7th 2005, 6:50pm
double post
Re: powering system
Thursday, July 7th 2005, 7:01pm
Is the BIOS of your Mainboard up to date?
THEdude
Re: powering system
Thursday, July 7th 2005, 8:51pm
Yes it's the latest non-beta 1011. My motherbord is an asus a8n sli deluxe (the one with the 1t bug -> never buy asus people))
