• 30.09.2026, 21:19
propurple
quick helped needed please asap
Friday, July 29th 2005, 11:42pm
ok heres my setup, just got a new motherboard so want to see if i can get a higher flow rate then .4 this time !! only using 2 x cuplex 1.3 and 360 rad.
ok as you can see quite simple setup, can someone tell me if that all looks right though, i had a similar setup to this last time but with a northbridge cooler on as well.
IS there an in or out plug on the exo 360 or doesnt it matter which way it goes through ? i would have it going from the top of the aquatube to the right inlet, and then the left going back to the cpu 2.
Can anyone see a problem with the setup like this, would the step between the aquatube and the flow sensor be ok. Im really trying to get a higher flow rate, any sugestions would be great
Thanks all !!
fabelmann
Re: quick helped needed please asap
Friday, July 29th 2005, 11:58pm
this setuo looks ok. i mean, i have a similar setup, just with an additional aquadrive lt und my flowrate is about 40 l/h at a frequence of 47 Hz with the aquastream. it's equal where you install the flow sensor because your setup is closed, so everywhere is the flow rate the same.
btw: in a system without jet(?) coolers like the cuplex pro or xt, it's nearly equal how fast your water is flowing. faster flowing causes less heat delivery, and contrary
