• 30.09.2026, 02:17
DaMightyWackO
6800LE Block wrong bolts
Friday, July 29th 2005, 2:36pm
Today i recieved a 6800LE block. For my little brothers pc. I have the same block and everything was okay in my case. But not this time. The bolts for the 4 middle holes are to big. So i can't screw them on. The screws (nuts) have a smaller diameter then the bolts. And the nearest construction market hasn't got screws that small. It's is not possible to drill larger holes for bigger screws.
So aquacomputer is supplying wrong bolts :) Are there more people with the same problem, to share the pain with ;)
(I think screw is the wrong word, nut it is called in English i believe)
Stefan_K.
Re: 6800LE Block wrong bolts
Friday, July 29th 2005, 2:43pm
Use the original screws together with the original backplate. ;)
DaMightyWackO
Friday, July 29th 2005, 8:30pm
Quoted from "Stefan"
Nope, there are no original screws. And those are ment to be fit :)
I used them the same way in my own computer.
Stefan_K.
Saturday, July 30th 2005, 2:37pm
Quoted from "DaMightyWackO"
How was the original cooler then mounted to the card ? ;)
DaMightyWackO
Saturday, July 30th 2005, 4:44pm
Leadtek, special screws which are mounted on the block it self, Combined with special bolts witch include springs.
In my own videocards case, the original cooler was mounted with plastic 'click mounts'. So no screws on both cards.
And again, with the block i recieved 1,5 months ago which is on my own card, there were correct bolds and screws.
Top_Nurse
Sunday, July 31st 2005, 7:58am
So maybe the place you got it from made a misteak? Maybe they got the right ones in stock? ;)
DaMightyWackO
Monday, August 1st 2005, 11:21pm
Quoted from "Top_Nurse"
Damn good idea :D
Maybe they can send me the right ones!
Top_Nurse
Tuesday, August 2nd 2005, 4:25am
So where did you get them from? I have been down this road before and you will get a lot faster response by e-mailing them at info@aqua-computer.de if you got them from AC direct. Otherwise contact the distributor you got them from and make them work for your business. ;)
