• 13.10.2026, 10:31
Top_Nurse
Plug & Cool Fitting question
Sunday, July 31st 2005, 8:07am
Greetings...
Can anyone tell me the manufacturer of the nickel plated metal G 1/8 and G1/4 90 degree elbows that AC sells? I need some matching connectors in 45 degree elbows and AC doesn't sell them.
Also looking for the same style panel mount connector that has black plastic rings on it instead of the blue colored that they use. Blue definitely does not make it in my latest project. :'(
Stefan_K.
Re: Plug & Cool Fitting question
Sunday, July 31st 2005, 8:07pm
All AC Connectors are
silver with black ring (metal connectors)
black with blue ring (plastic connectors)
And no .. we don´t tell anyone the manufacturer of the connectors.
Regards
Stefan
Top_Nurse
Sunday, July 31st 2005, 10:34pm
Well can AC get me some 45 degree metal fittings from wherever you get them from. I know it seems silly to some, but I want all my fittings to match. :)
Stefan_K.
Sunday, July 31st 2005, 11:37pm
Ask Stephan at info@aqua-computer.de ;)
Top_Nurse
Monday, August 1st 2005, 12:17am
Quoted from "Stefan"
Okay I will :) However, the metal bulkhead connector for some reason has a blue ring on it. :'( I need black plastic rings.
pharao
Monday, August 1st 2005, 12:18am
Quoted from "Top_Nurse"
paint 'em ;)
Top_Nurse
Monday, August 1st 2005, 1:30am
That's a thought. What kind of paint will stick to whatever they made those rings out of?
Tunage
Tuesday, August 2nd 2005, 9:31pm
Just take a black magic marker to'm TN.'swhat I did in a couple instances.
Max_Payne
Wednesday, August 3rd 2005, 12:59am
Hy,
Legris (www.legris.com) makes that what you are search
Gruß Max Payne
