• 02.10.2026, 08:11
REDG
TwinPlex for AOpen i915GMm-HFS
Tuesday, September 6th 2005, 10:03pm
Hello everyone
To install TwinPlex on a AOpen i915GMm-HFS I think it's necessary to use Blende GeForce 6800 for the processor and Blende Gigabyte for the chipset.
Unfortunately AquaComputer doesn't propose TIFF-Datei for these two "Blenden".
It's possible to realize them easily...
Thank you for your assistance
M'en Bati Sièu Nissart
REDG
Re: TwinPlex for AOpen i915GMm-HFS
Tuesday, September 6th 2005, 10:18pm
Or to realize a sketch with dimensions
Ze@lot
Wednesday, September 7th 2005, 6:45pm
your gonna have to take a chance on a twinplex fitting your
CPU. this mobo has a bad rep as AOpen used there own hole
placements on this board so none of the aftermarket HFS
CPU coolers will fit. maybe if it does not fit you could make
your own bracket.
imo tho id ditch it and get another board. one that uses
standard hole placements. sorry i cant get any other advise
as im not into micro-ATX boards.
good luck
Ze
REDG
Thursday, September 8th 2005, 2:49pm
I think that it's possible...
Chipset : 6.3 cm
Processor : 7.5 cm (5.3*5.3 cm)
If I can have these dimensions...
Nobody have these "Blenden"?
Hummerman
Sunday, September 11th 2005, 9:24pm
from A to B 7,50 cm
NikoMo
NikoMod
Sunday, September 11th 2005, 9:25pm
hi, the normal twinplex has a hole-to-hole-distance of 62mm. so, he might fit.
REDG
Sunday, September 11th 2005, 9:53pm
Quoted from "Hummerman"
from A to B 7,50 cm
Thanks ;)
REDG
Sunday, September 11th 2005, 9:58pm
Quoted from "NikoMo"
hi,
Yes, I think too that it's preferable to use these. 62~63 mm :P
Thanks a lot :D
