• 30.11.2026, 15:49
Mr_modnaR
ATX Questions
Wednesday, September 28th 2005, 11:13am
Hi all...
got two for you today:
1. On the 20 pin atx plug, which two pins is it that you need to bridge to turn on the power supply, you know, like the one that AC sells.
2. if you have a 24 pin atx plug which has a 4 pin bit on the end that you can detach to make a 20 pin plug, does the 4 pin part have a permanantly on power line that you could power the aquaero with even when the computer is off, like the PS_ON line that they recommend to use?
many thanks
Stefan_K.
Re: ATX Questions
Wednesday, September 28th 2005, 1:53pm
1. black and green
2. no
Mr_modnaR
Re: ATX Questions
Wednesday, September 28th 2005, 4:41pm
many thanks Stefan! does it matter which black?
Quoted
oops i think that the PS_ON line is to turn the power supply on and off, is it not? (D- bad research! ;D)
Re: ATX Questions
Wednesday, September 28th 2005, 5:17pm
Quoted from "Mr_modnaR"
No, they are all the same.
Mr_modnaR
Re: ATX Questions
Wednesday, September 28th 2005, 9:25pm
cool, cheers shoggy
