• 05.10.2026, 23:55
Top_Nurse
More on Multiswitch's
Wednesday, November 9th 2005, 11:16am
Okay I have a Multiswitch here and I am trying to decipher the instructions.
  • Where does the Multiswitch get power from?
  • Does the power come from the Aquaero, the PSU Molex, or through the Aquabus?
  • If you hook up the Multiswitch to the Aquaero via the Aquabus do you also need to use the USB cable?
  • Can someone please explain what the Configuration jumpers do as listed on pages 9 and 10 of the manual?
x-stars
Re: More on Multiswitch's
Wednesday, November 9th 2005, 12:06pm
Quoted from "Top_Nurse"
1) trough the Molex-Connector (directly from the psu)
2) ?? - same question - trough the molex-connector :P
3) No, if you connect the ms to the aquabus you mustn't connect it to usb, only one connection is allowed. To connect it to the aquabus you have to use the 3-Pin-cable (same like the aquastream-tacho-cable)
4) i don't have the manual :-/
Top_Nurse
Monday, November 14th 2005, 12:44am
Thanks for the information. ;D
Is it possible to hook up additional flowmeters to the Multiswitch as I would like to run three?
If I attach an Aquastream controller to the Multiswitch I assume I shouldn't run power to the controller correct?
Will I have the same software capabilities on the Aquastream attached to the Multiswitch that I would with the other two attached to the Aquaero?
IIRC I can run two Aquastream controllers off the Multiswitch, correct?
What is the better way to connect the Multiswitch. From the Aquabus or directly to the USB?
x-stars
Monday, November 14th 2005, 7:22pm
Hm, you can connect more than one devices to the aquaero (two multiswitches and a tubemeter) - but there is only one Tab for the tubemeter in the aquasuite, so I assume it's only possible to connect one tubemeter to the aquaero, the others must be connected to usb (but there you can connect up to 127 devices per root-Hub, so theoreticially you can connect 500 and more devices in a system (most mobos have at least two root-hubs and it's possible to get more by using PCI-cards).
Quoted
That's right, choose the connection cable or use the molex, but don't use both at the same time.
Quoted
Yes, I think so.
Quoted
Another yes, so with a aquaero and a multswitch you can connect up to 4 aquastreams (and if thats not enouhh: you can connect more than one aquaero to a system ;D)
Quoted
[/qoute]
I would connect the tubemeter to the aquabus - there you can implent it to the emergency-shutdown-settings.
For the multswitch I would choose the USB-Port, 'cause you will have your own script-window and so on just for the multiswitch.
