• 15.11.2026, 00:45
MUFFDIVER
evo 1800 rad
Thursday, November 17th 2005, 6:50pm
Is there going to be a mounting plate for this?
fabelmann
Re: evo 1800 rad
Thursday, November 17th 2005, 7:27pm
no, i don't think so. when i was talking to stefan k. from aqua computer berlin, he said, that mounting a 1800 rad on the side of your case is possible by 4 m4 scews and some "Abstandshalter" ( bolts, which are several cm long to make some place between case and rad)
like that one, but you do'nt have to choose the bolts that long, depending on what you are cooling
MUFFDIVER
Re: evo 1800 rad
Monday, November 21st 2005, 4:20am
hmm water speed must be slow with the 1800?
edboswell
Re: evo 1800 rad
Monday, November 21st 2005, 2:17pm
nope with a decent pump - eheim 1048 the water goes round my 1800 pretty fast - with 6 blocks to go through... the water is sprayed onto the res. quite effectively. I bought the aquero (will flow meter thing) so i will post the speeds as soon as it arrives :)
MUFFDIVER
Re: evo 1800 rad
Monday, November 21st 2005, 2:30pm
cheers mate 8)
Mr_modnaR
Re: evo 1800 rad
Monday, November 21st 2005, 8:40pm
Be warned tho, it IS larger than most cases, so get it if you don't mind an overhang!! ;D
MUFFDIVER
Re: evo 1800 rad
Wednesday, November 23rd 2005, 5:43pm
im stripping to crp pcs down and using the frames or chassis, and using mdf to make a frame for it,understand that as i lost my self in it. il post a thread when i start it :)
MUFFDIVER
Re: evo 1800 rad
Friday, November 25th 2005, 1:46am
so will 5 360 mounting covers fit the 1800 as it lookslike it just might?
edboswell
Re: evo 1800 rad
Friday, November 25th 2005, 11:36am
yes they will but are you going to buy 15 fans... i have got fans but only very quiet ones ... and they come at a price.. about £15 a fan inc vat. - do the maths 15*15= £225... not worth it if you ask me... i might get 15 over time (1 a month) but not in one go. You do not need them just for protection it is not needed... if you think it is then you don't take enough care over your computer....
MUFFDIVER
Re: evo 1800 rad
Saturday, November 26th 2005, 5:49pm
Quoted from "boswell"
How So?
