• 12.10.2026, 00:37
Isaksson
Need some help with what i should buy.
Thursday, December 1st 2005, 9:50pm
Hello.
First of all i will tell you that iam from sweden and my english is not the best, but i hope you understand.
I use water cooling right now, but i will now upgrade it some.
I use a Eheim 1046 Aquastream and a couple of waterblocks, but now to my question,
here is what i plan to order:
aquaero 4.00 USB Fan-Controller, VF-Display 139.00
internes USB-Anschlusskabel 70 cm 2.99
Anschlusskabel for Durchflusssensor (for aquaero) 2.99
aquaero Durchflusssensor without fittings 23.99
Multi-Color Illumination module BLUE/RED 7.90
aquabus Kabel for tubemeter 3.99
tubemeter USB 29.90
Anschlusskabel aquabus/Tacho f. aquastream Retail 2.90
what should i use to connect the aquastream to the aquaero?
is it possible to use both tubemeter and aquastream to aquaero and connect it to aquabus?
i was also planning to buy 2 Aqua Aquaero - Water Temp Sensor but i dont find it in the store, anyone knows why?
What fittings should i use with the aquaero Durchflusssensor?
and the last question, do you see anything that i have forgot in my order to connect it, like cables and stuff like that.
Thanks for the help.
MUFFDIVER
Re: Need some help with what i should buy.
Thursday, December 1st 2005, 10:41pm
i think it is all there but i havent checked. so id wait out for shoggy or another member.
Thursday, December 1st 2005, 11:07pm
You won't need "Anschlusskabel aquabus/Tacho f. aquastream Retail". The right cable for a connection between the Aquaero and the Aquastream is "aquastream Verbindungskabel (ab Rev. 1.5) 10cm".
I have no idea how to find it within the categories. Below "Hersteller" you can see a dropdown menue. Click on it and choose Aqua-computer. The you will get a list with all products including the cable and temperaturesensors.
Maybe you want to use the shop of AC Berlin. It's much easier to handle :)
You can connect the Tubemeter and the Aquastream without any problems because the Aquastream uses an other connector.
You will also need two G1/4 fittings for the flowmeter.
I highly recommend that you get the plug n cool inline sensor to measure the temperature of the water. This temperature is ideal to control the power of the fans.
Isaksson
Friday, December 2nd 2005, 4:52pm
Hello.
Thanks for the help, now i have one question more,
i think that my pump is not so good is it possible to buy
the Eheim 1250 (Version Deutschland) and connect it
to the aquaero?
I guess that pump is much better.
And thanks again for the help.
Friday, December 2nd 2005, 5:32pm
No, the only pump you can connect is the Aquastream. By the way: you can "overclock" it to get a higher flow. This is a normal function and won't void the warranty.
Isaksson
Friday, December 2nd 2005, 6:11pm
Aha okey.
how about the "overclock"?
what do i have to do to make it happen, ans what flow is it possible to get with it at max?
thanks
Friday, December 2nd 2005, 6:26pm
Overclocking means that you rise up the frequency. The controller is able to generate a signal with a frequency between 42 and 74Hz. The higher the frequency, the higher your flowrate is ;)
The default value is 47Hz.
As an examle: I achieve 33 l/h with 47Hz while I get 57 l/h with 74Hz. That's an enhancement of around 70%!
You can control the frequency directly with the Aquaero or the Aquasuite software.
Isaksson
Friday, December 2nd 2005, 6:48pm
Okey i see.
Then i will try that when i have ordered my stuff.
You realy helped me out here, if i got any more problem then
i will post it on this forum, very good answers and fast too.
Thanks again for the help and thanks for this forum.
Bye for now.
edboswell
Friday, December 2nd 2005, 7:50pm
does the pump get louder though if you overclock it? (louder than the ehiem 1048 )? thanks
Friday, December 2nd 2005, 8:25pm
It might be a little bit louder but this depends on how good you uncouple the pump from your case. If you have a few minor vibrations they will sound a bit higher.
Altogether the difference is very small.
Mr_modnaR
Friday, December 2nd 2005, 8:32pm
shoggy: is the way you showed some time back with the foam, the best way to mount the pump in the fmj?
cheers
Isaksson
Friday, December 2nd 2005, 8:48pm
Iam planning to change to plug&cool in my watersystem,
so my question is what fittings should i use with my
Aquastream (Eheim 1046)?
and is it possible to connect the plug n cool inline sensor
direct to my aquatube?
and what fittings plug&cool should i use with my aquatube?
and i need some "plugs" to Multi-Color Illumination module BLUE/RED so that i can connect it to my aquatube?
thanks.
Friday, December 2nd 2005, 8:58pm
Mr_modnaR, I would say yes ;D Very silent and cheap solution if you want to use the FMJ anyway.
Isaksson, all AC products excepting the radiators and the flowsensor are using G1/8. For the Aquastream you will need the adapter-set.
To use the PnC inline sensor with your Aquatube you will need a normal connector where you can plug it in. Or you could use a t-connector.
Mr_modnaR
Friday, December 2nd 2005, 9:22pm
Quoted from "Weihnachts-Shoggy"
cheers, where did you get it (the foam)? ta
Friday, December 2nd 2005, 10:59pm
Was the package of two cold cathodes *g*
Isaksson
Friday, December 2nd 2005, 11:20pm
The adapterset is the same as these right?
Adapter Eheim 1046 Druckseite mit Dichtung
Adapter Eheim 1046/1048 Saugseite mit Dichtung
and with these adapters then i could connect the
G1/8 to the adapters?
and by the way what means "mit Dichtung"
with?
Thanks
pharao
Friday, December 2nd 2005, 11:39pm
Quoted from "Isaksson"
with?
http://www.dict.cc/?s=Dichtung&btngo=Go%21
dict.cc is your friend :D
Top_Nurse
Saturday, December 3rd 2005, 10:00am
Here is another G to E site: http://dict.leo.org/?lang=en&lp=ende
Isaksson
Saturday, December 3rd 2005, 12:11pm
Okey, thanks now i know what that word means,
someone knows the answers to my other questions
in that post?
Thanks
-edit-
maybe this is the right converter:
Anschluss-Satz für 1046 ohne Anschlüsse (nur Adapter)
-/edit-
-edit2-
Is the pump 1046 G1/2?
-/edit2-
