• 02.10.2026, 00:27
edboswell
sensor position..
Saturday, December 10th 2005, 7:49pm
right i have 5 temp sensors to be put in my case somewhere... cpu for def. gfx? - the core (centre shiny bit right?) chipset - is it really worth the effort? harddrives... where should i put them on the back.. selotape it on :/ ? last one case or ram? ... everything is watercooled so its not thattt easy to take things off.. any suggestions thanks
ed.
Top_Nurse
Re: sensor position..
Saturday, December 10th 2005, 8:05pm
If your watercooling then why would you want to use the regular thermal sensors? Why aren't you doing water temps? Also an ambient temp measured on the outside of the case is also nice.
edboswell
Sunday, December 11th 2005, 3:43am
ah good idea... i am doing a water temp... but on the aquaero you can have up to 6 temp sensors in total...
Tiak
Sunday, December 11th 2005, 6:28pm
hdd for exampel, put it on the Top with some Tesa or the Case Temperature.
It´s not that exact but +-1 °C is O.K. I guess.
MfG Tiak
