• 07.10.2026, 06:35
edboswell
connecting usb aquaero
Wednesday, December 14th 2005, 12:51am
Which pins do the usb cable go into on my motherboard i have a dfi sli dr on it the usb connector pins go (Standard i believe) -
say * = no pins and / = pin
what should be the correct way (in terms of the colour of wire slotting into the pins) thanks :)
Ed.
MUFFDIVER
Re: connecting usb aquaero
Wednesday, December 14th 2005, 4:00am
WUD LOVE TO HELP BUT I AINT SURE? UM TN WHERE R U THIS EVENING?
oops sorry for caps ** 8)
Top_Nurse
Wednesday, December 14th 2005, 10:50am
Well I took a spin down to Palm Springs in my Volvo 850 Turbo Sedan so I have been off line for a bit. Who would have ever thought that the car drives better at 100 MPH (160 Km/H) than it does at 70 MPH (113 Km/H)? ???
Attach the red lead (+5v) to Pin 5 on the Tubemeter. Attach the red lead to pin 1 on your MB.
edboswell
Wednesday, December 14th 2005, 10:09pm
why isn't my aquaero connecting >:( >:( i swear iv done everything right??? shoggy any help as you are the ac gurro ;D
Wednesday, December 14th 2005, 10:49pm
Compare it with your wiring, you will have to turn the first picture ;)
edboswell
Wednesday, December 14th 2005, 11:20pm
ok i have done that but it still isn't being brought up in aquasuite :/ is there something else i have to do to enable it. I will try in another usb slot but i dont think theres anything wrong with this one...
Wednesday, December 14th 2005, 11:21pm
Is this a new 4.00 Aquaero or 3.07?
edboswell
Wednesday, December 14th 2005, 11:26pm
4
MUFFDIVER
Wednesday, December 14th 2005, 11:40pm
Are they USB2 or 1.1, probably sounds stupid but just a thought?
8)
edboswell
Wednesday, December 14th 2005, 11:43pm
usb 2... i thinkkk that maybe theres some jumpers or something to enable these "extra usb slots" because the other one isn't working aswell... i have the dfi lanparty sli dr if anyone else knows whats jumpers to change... im googling atm
edboswell
Thursday, December 15th 2005, 12:20am
it was a jumper problem everything is sorted now :) thanks
Top_Nurse
Thursday, December 15th 2005, 9:02am
Jumpers ??? You mean MB BIOS switches?
edboswell
Thursday, December 15th 2005, 10:42am
hmm i mean there are some pins with a little blue thing (jumper - i think) next to the usb slots within my motherboard... and the blue thing had fallen out - i think it simply lets the usb have power (eg actually operate). So i put it back in and all works... but my lian li case (pc 71) feet have broken now - i think because my case weighs about 50 kg.. so i need to buy new ones.. any people from england know where to buy some that will fit this case (pm me)
MUFFDIVER
Thursday, December 15th 2005, 10:31pm
umm try a diy store and get some feet and drill holes to mount them. but some heavy duty 1's like dj's rackmount feet or summin along those lines.
Or summin like this, they will hold 150kg (apperently)
http://www.electroenoc.se/?articleId=263&lang=UK
