• 06.10.2026, 21:16
Isaksson
Change speed of fan
Thursday, January 5th 2006, 11:02pm
Hello,
i have a new problem now :'(
I cant change the speed of my fans with aquaero,
or maybe iam just stupid,
i start aquasuit then go to the tabb Fans then i pick the fan that i wanna change the speed of(fan selection)
then (fan mode) i pick Set Power input and then i set power input to 20 and i see on the status that he change the performance to 20% but still the fan goes at the highest rpm.
i stoped the fan with my finger and then the rpm when to 0 so he calculates it right.
i have tryed to set the rpm to but that dident work either.
i have tryed with 3 fans.
am i doing this the wrong way?
x-stars
Re: Change speed of fan
Thursday, January 5th 2006, 11:11pm
Hm - seems to be a "bigger" problem, in the aquaero-forum was a guy with the same prob :D.
Try to make an epprom-resett, that should help. The latest firmware (4.09) is installed (if not, do so :))?
Isaksson
Thursday, January 5th 2006, 11:14pm
Thanks.
i will try this and then i will let you know.
Isaksson
Thursday, January 5th 2006, 11:35pm
I did as you told me (updated) and now it works,
thanks.
