• 14.11.2026, 13:48
Isaksson
Connect the aquastream
Thursday, January 5th 2006, 7:20pm
Hello.
I have a old aquastream on the front the name is not aquacomputer it says "Mist"
but when i read the manual for it it says that i could connect it to a aquaero and i have an aquaero-bridge connector.
the first time i connect it to my aquaero then the oump just started for like 1-2 sek then turnd of then started again.
so i disconnected it and connected the power back to the aquastream, and then i started the computer and fixed some stuff in aquasuite.
and when i try to use the aquaero-bridge now the pump doesent start at all.
any ides?
and by the way i should not have the power connected to the aquastream when i use the aquaero-bridge, right?
Thanks
Re: Connect the aquastream
Thursday, January 5th 2006, 8:18pm
Quoted from "Isaksson"
Right.
The Pump or Controller is named "Mist" ??? Can you take a photo? Do you know the version of your controller?
Isaksson
Thursday, January 5th 2006, 8:31pm
Hello.
Its the controller that has that name,
here is some pictures
http://213.113.110.198/aquacomputer/1.jpg
http://213.113.110.198/aquacomputer/2.jpg
http://213.113.110.198/aquacomputer/3.jpg
http://213.113.110.198/aquacomputer/4.jpg
http://213.113.110.198/aquacomputer/5.jpg
http://213.113.110.198/aquacomputer/6.jpg
just ask me more if you need better pictures or if there is some more info that you need.
edit:
i dont know the version, cant find it anyware
Katzenfreund
Thursday, January 5th 2006, 8:38pm
Can you please post a screenshot of the aquadrive side, where it is listed and named?
Isaksson
Thursday, January 5th 2006, 8:40pm
You mean a better picture of the backside of the controller?
like this picture
sorry i guess you mean somewhere from aquasuite?
x-stars
Thursday, January 5th 2006, 8:49pm
As you can see on the picture, your aquastream-controller is a revision 1.0, did you buy the right cable? I'm not quite sure, but I think, the version 1.0 isn't aquaero-capable, yet, you need a new controller or sent your controller to AC to get an update (6,00 Euro + all shipping costs) :-/.
Isaksson
Thursday, January 5th 2006, 8:56pm
Thanks for the help,
but if i cant connect it to aquaero why is there a aquaero-bridge, and in the manual to my aquastream:
In the case the aquaero and the aquastream are connected via a 10-pin flat cable...all data of the pump can be supervised and monitored on the aquaero.
so thats not true?
x-stars
Thursday, January 5th 2006, 9:08pm
so thats not true?
The aquaero wasn't available, when the AS was released. Since Aquaero Version 1 they startet two more tries with whole new Hard- and Software(Firmware)-Layouts - so when the first aquaero (Rev. 3.07) was released, the aquastream-Controller-Firmware wasn't up-to-date anymore :-/.
Isaksson
I have the wrong cable i have this one
aquastream Verbindungskabel (ab Rev. 1.5) 70cm
thats no good,
does anyone knows whats the diffrense between that cable and the one for Rev. 1.0?
Isaksson
Thursday, January 5th 2006, 9:10pm
so it wont work for me even if i get the right cable, the one for Rev 1.0?
x-stars
Thursday, January 5th 2006, 9:18pm
It might be, that version 1.0 will work with the aquaero (with the right cable of course) - that's the problem: I can't remember it precisly (there was anything with version 1.0 :'().
The diference with two cables was that one pin isn't connected, you can use one of the cables with every controller, but don't ask me which one - lets wait for someone who can remember better than me :-[.
Isaksson
Thursday, January 5th 2006, 9:24pm
aha okey.
so rev 1 only use 9 connection and the other revs uses all 10 connections.
well if i rebuild this cable 10 times then i quess it could work, but thats the hard way.
or maybe something already is broken when i first tryed with the cable for rev 1.5.
Thursday, January 5th 2006, 9:27pm
AFAIK the controller must have at least firmware version 1.04 if you want to use it with your Aquaero.
Isaksson
Thursday, January 5th 2006, 9:32pm
and how does i find out my firmware version?
what do you think is the best for me to do?
buy a new controller?
Thursday, January 5th 2006, 10:09pm
I don't know the shipping costs to germany (for updating) and back to your town but I think a new controller would be the best choice.
Isaksson
Thursday, January 5th 2006, 10:49pm
Okey.
I guess you have right.
is there a controller to buy or do i have to send my and make a update?
MUFFDIVER
Friday, January 6th 2006, 12:52am
nope you just buy the new 1 and stick the old 1 on EBAY ;D
Isaksson
Friday, January 6th 2006, 1:02am
Thats true, do you wanna buy it ;D
this is what iam planning to buy
aquastream Controller Platine 3.5 (ohne Pumpe)
If i later wanna use 2 pumps in my system how do i connect two pumps to the aquaero?
MUFFDIVER
Friday, January 6th 2006, 1:07am
And no to your question. 8)
And to be honest i dont know was going to post that myself later this year. But seems as you have asked... SHOGGY???
x-stars
Friday, January 6th 2006, 1:18am
I am not Shoggy, but here's the answer ;D:
There is a cable with 3 instead of two connectors, so you can connect two Controllers. You need at least one controller of revision 3 or 3.5 to change the adress of this controller (via jumper) :D.
