• 20.11.2026, 06:45
rdrradon
What fittings fit the Cuplex XT?
Tuesday, January 10th 2006, 4:25am
I ordered my Cuplex XT from Sharka, and got the wrong fittings with it. I meant to buy 3/8" ID 1/2" OD fittings for it. I searched high, and low at the local hardware store, and nothing seemed to fit the threads right. So could I use Koolance, or DangerDen 3/8" fittings?
melon
Re: What fittings fit the Cuplex XT?
Tuesday, January 10th 2006, 8:23am
You need G 1/8''.
...The connection threads in the bluish colored plexiglass are manufactured in G 1/8"...
(Ps: man kan über treiben)
Top_Nurse
Tuesday, January 10th 2006, 3:42pm
You can get 3/8" ID x G 1/8 hose barbs from Aqua Computer and Sharka should have them as well.
