• 29.09.2026, 20:48
Top_Nurse
SLI Typ 1 problems
Tuesday, January 17th 2006, 9:07pm
Anyone else had problems in getting the 8mm compression fittings to work with the TwinPlex Pro SLI Typ 1 cooler?
Top_Nurse
Re: SLI Typ 1 problems
Wednesday, January 18th 2006, 10:59am
No one has had any problems or no one else has tried to use the G 1/8 8mm compression fittings?
Here is my problem:
I think I can turn down the nuts, but I am wondering if others have had the same problem.
CygnusX1
Wednesday, January 18th 2006, 11:23am
As you know AC uses 8/6mm and your fittings are simply too big. They won't fit, but you can try do put in one fitting with an angle, perhaps it fits then. I have 8/6mm fittings and they are very close, but they fit.
MUFFDIVER
Wednesday, January 18th 2006, 8:43pm
Yeah looks dodgy i must admit... Umm... dont know how to help TN sorry.
melon
Wednesday, January 18th 2006, 9:54pm
Take ONE of these and it will work!
(Ps: man kan über treiben)
Top_Nurse
Wednesday, January 18th 2006, 11:01pm
Quoted from "melon"
MUFFDIVER
Thursday, January 19th 2006, 12:12am
Quoted from "melon"
Check you out. 8)
melon
Thursday, January 19th 2006, 1:22am
8)
;D
