• 16.10.2026, 09:30
calmar
Aquaero sensor questions
Saturday, March 4th 2006, 7:04pm
Hello,
I have a few questions to ask, trying to make sensors work good.
Is there any manual (I didn't find any) in english for the aquasuite ? I'd like the options of the "Sensors" tag to be explained to me.
For example, what exactly means "Reference value in °c" ? Is it the temp that the device I'm monitoring is supposed to be (the optimal temp) ?
I would really appreciate if someone tells me exactly how each option of "Controller settings" and "Limits" work and make the whole thing react.
If I dare : does someone know the good settings for some different kinds of sensors :
the classic one
a watercooling one
and another w/c one
Thanks for help ! ;)
calmar
Re: Aquaero sensor questions
Tuesday, March 7th 2006, 3:41pm
So ? Anybody can help ?
Top_Nurse
Friday, March 10th 2006, 9:55am
Quoted from "calmar"
Hello,
Aqua Computer does not provide technical support on products they do not sell. If you wish to use non-AC sensors you should have the wherewithal to get the correct information from the people who made your sensors.
Also as a FYI they don't appreciate people posting pics of their competitors products on their forum. After all this IS a manufacturers forum. You may be able to get better answers at WizD, bit-tech, or the [H]ardForum.
There is no English manual, but since the Aquasuite is in English it should be pretty straightforward. :)
BTW, your first and third pic is a standard AC item so the default Aquaero and Aquasuite settings will work just fine.
x-stars
Friday, March 10th 2006, 3:19pm
All Sensors will work fine (I use the second sensor in my system and it works good). In Generell you don't have to change the sensor-offset, the sensors work all in the same way and so there is no difference.
An english manual is not available (officially), but I remember that there was an inofficial translation in another forum (but don't ask which one ??? ;D).
