You are not logged in.
Quoted from "Top_Nurse"
IIRC there is a problem in that the .NET Framework needs version 2 to run in XP64 and the Aquasuite doesn't work with version 2. Perhaps someone who knows can more fully explain the issue.
Quoted from "boswell"
there is no reason to use 64 bit though... no reason at all. The only thing that 64 bit enables you to have is more RAM, but this is pointless because you most likely can't afford to have more than 4gig and anyway even if you did your motherboard wouldn't surport it. If you did have a motherboard that surported more than 4gig then it would be a server motherboard in which case you would normally be getting a server operating system.
64 bit only offers incompatiblity nothing more.
Boswell.
Quoted
and it smokes in gaming.
;D
) has made a package
