• 15.11.2026, 15:19
Ze@lot
Re: Project: Hydroponic Chamber
Friday, October 28th 2005, 2:14am
ok im still puzzled with the fan set up. i sorta remember hearing that you can connect more than one fan to the fan connectors on a aquaero. i am losing (fan 4) connection to run my second flow sensor.
i was planning on having 2 fans on each of the other 3 fan conections. lets take (fan 1) for an example. if i set the fan speed in the aquaero suite to lets say 1500rpm, will both fans be running at that speed or will i have to set it to 3000rpm for both fans to run at 1500rpm ??
or will i be better off running all the fan independently via a multiswitch ?
Top_Nurse
Friday, October 28th 2005, 3:37pm
Quoted from "Ze@lot"
If you want to run two fans off the same Aquaero header just wire them in parallel. However, just use one of the fans RPM lines so you can control the set. Make sense?
Ze@lot
Thursday, February 9th 2006, 8:15pm
sorry TN, i must have missed this reply. im a bit confussed over the parallel, what do ya mean ?
i found out that the aquaero, that i bought as a v3.07 is in fact a v4.00. looks like they were putting in the PCB's in earlier than offically announced. either that or i got lucky.
if any1 wants to check you have to remove the front panel and under where the switches are located, should read " aquaero vX.XX.
so happy days. as 120mm fans are rated at 2.16 watts, i can run 3-4 fans to each channel. im gonna go with a 3 fans per channel which should lead to nicer wiring. just not sure what you mean by parallel ?
Infiltraitor
Friday, February 10th 2006, 1:42am
Timstone
Friday, February 10th 2006, 11:28am
Zealot:
I have a question about the case. Where have you put your HDD? The slots destined for the HDD's are taken by a dual 120mm radiator. So where is the HDD?
Nice mod so far, you've got lots and lots of room and the cube. Me like! 8)
Men may control the free world, but women control the boobs. Brent in Player vs. Player
pharao
Friday, February 10th 2006, 11:46am
Quoted from "Timstone"
Zealot:
I can see two Aquadrives here.
And I think it'd be a shame installing two aquadrives and not putting your HDDs in there ;)
Timstone
Friday, February 10th 2006, 11:51am
Alrighty then! Thanks for the reference picture!
I should have read it first, then post. :-X
MUFFDIVER
Friday, February 10th 2006, 9:18pm
would look sweet all in black but nice so far, + when we getting an update?
Ze@lot
Saturday, February 11th 2006, 2:55pm
top site infiltraitor, thanks for the replies.
i had to put the project on hold, but i recently started work again. i now have the orange acrylics so expect a update shortly.
MUFFDIVER
Sunday, February 12th 2006, 5:55am
kewl.
Ze@lot
Monday, March 6th 2006, 8:12pm
grrr posted the above by accident i was trying to change title.
i have given up on the hydroponic idea as it was proving far to difficult with my limited skills. changing the name to fire mountain.
any here is the
long over due update.
i got the builders in next week so im prolly not gonna be able to do much for the next week or two. but at least after i can hopefully get up to speed again, as im nowhere near where i wanted to be at this stage. but hey that's life for ya ;)
this arrived for me the other week along with some other sheets which are safely stored away till i need them.
i had always planned on a orange & black case. i had a hard time finding the acrylic the right colour for me. this is not classed as UV reactive but rather as flouresent, but it was discribed as light gathering & live edges. which sounds just about right, there will only be the edges on show when i have finished.
but before i could start on the acrylic, i needed to get the dremel on the standard AC grills. it had bugged me from the time i decided on the rad placements that the front didnt look like the back as the grill was hoizontal rather than vertical. so off came all the bars. to be replaced with some modders mesh at a later stage. which it looks like im gonna have to talk to bill about as i have had no luck in finding a good alternitive in the uk.
this is the end result after a lot of sweat & a few bad words. i have this & the 240 grill 100% done, but the 360 is about 90% complete. the sound of a file on stainless steel is worse than nails on a blackboard to me. even ear plugs wasn't doing much, so i'm having a rest from that. plus the acrylic was calling out to be worked on.
my modest work bench, tho not much to look at, it still does the job. as i been able to so far complete the 120 grill thus far.
i got the idea after seeing franklin's alumax case mod as seen on the AC forums. but he left the bars in place, so not exactly the same thing. he also lit his with led lights. i'm just gonna drill a series of small holes in the case just under the surrounds, and just let the light come from the internal lighting. as when lit from the back it really starts to bling. as seen in this picture with the sun coming in from the window.
i have been working on 240 surround today, tho i didnt get a chance to finish it before i had to pack everything away ready for the builders in the morning.
i started by cutting a piece of the acrylic just a bit wider than needed. then i drilled and bolted the cut out grill to it. this helped me keep the acrylic rigid while i was working on it. i got the modders fav sharpie marker and drew a line around this as my safety line ( only a file past this line ). i drilled a series of holes in the middle section, just the difficult bits like the corners. then out came the coping saw and i removed the middle, before sanding it down to the line with me dremel fitted with a sanding drum.
then it is all hand filing from the line down, so that it is flush with the grill. but that is gonna have to wait till another day.
lol im gonna get plastered 2morrow :D
Carbine
Re: Project: Fire Mountain ( named changed 06-03-0
Tuesday, March 7th 2006, 7:17am
Hey mate looking good! Just realised you the same guy who posted pics similar to my ideas on KPC forums :D
btw where do you get the standoffs for the mounting f the control unit?
Infiltraitor
Tuesday, March 7th 2006, 4:29pm
Quoted from "Carbine"
where do you get the standoffs for the mounting the control unit?
If it's the aquastream controller to aquaero standoffs you're on about, I'm pretty sure they come already installed on the back of the aquaero.
I could be wrong, though ;)
Ze@lot
Wednesday, March 8th 2006, 12:07am
lo carbine, how's your project coming on ?
iirc you do get 2 standoffs with the aquaero, but imo they are not long enough. i found some from maplins that were 30mm long, they only come in white nylon. so i had to get a black permenant marker on them.
Infiltraitor
Wednesday, March 8th 2006, 9:03am
IIRC you screw the aquastream controller's faceplate standoffs (short) into the aquastream standoffs (longer) and you're golden ;D
Carbine
Wednesday, March 8th 2006, 11:39pm
Cheers people... and yeah Zealot.. i'm still waiting for my case. The place i'm getting it from is STILL outta' stock :'(
Ze@lot
Saturday, March 11th 2006, 2:46pm
Quoted from "Infiltraitor"
lol dont ya just hate a smart arse ;)
yeah unfortunatly the sole uk suppliers are a bunch of ignorant bankers, so i got mine directly off MMods. still took 3 weeks to arrive tho & paying import duty sucked :/
Infiltraitor
Sunday, April 23rd 2006, 5:07pm
Any updates due on this?
Happy birthday BTW ;D
Ze@lot
Monday, April 24th 2006, 10:33pm
tyvm Infiltraitor  ;D
i have no picture so i have not posted anything. i have all the w/c stuff fitted now, tho i have now deicided to replace the tubing with the red uv stuff. been working on the acrylic & wiring.
i had some trouble sourcing the wiring, maplins sell all the connectors but couldnt supply me with the correct wiring. i also tried all my local electrical wholesalers & auto parts stores.
then i found these peeps  http://www.rapidelectronics.co.uk/rkmain…71067&XPAGENO=1
the acrylic stuff is coming along but at a slower rate than i expected, but i know im gonna have to get the side panels laser cut.
will update with some pics soon
Infiltraitor
Monday, April 24th 2006, 11:34pm
Nice find ;)
Looking forward to the updates
