• 09.10.2026, 19:12
aquasuite 4.38 + aquaero Firmware 4.10
Tuesday, May 2nd 2006, 7:08pm
You can DOWNLOAD a new aquasuite version. It also includes a new firmware. All known bugs have been fixed and there a few new features:
- change the Text of stand-by mode
- eeprom reset within quasuite without restart of aquaero or PC
- parameter -min can be used to start aquasuite minimized
Note for those who have problems when using the tubemeter and aquastream together. Besides the aquaero<->aquastream bridge cable you have to connect the aquastream controller to the PSU. You should use the same cable which is also powering the aquaero.
Do this only when you have problems with that combination!
edboswell
Re: aquasuite 4.38 + aquaero Firmware 4.10
Wednesday, May 3rd 2006, 1:31am
annoying bug - under the sensors tab the "max limit in C" and min limit and alarm automattically go to 100 even though i have tried to set them at x (25 degrees for example). what should i do?
heed
Sunday, May 28th 2006, 4:10pm
Hi, I also have this bug and was wondering if a new version is in the works to fix it? Thanks!!!
Monday, May 29th 2006, 1:27am
Sebastian said it will be fixed but I don't know when this new version will be available for download :-/
heed
Monday, May 29th 2006, 3:57am
Thanks for checking, Shoggy!
