• 22.11.2026, 21:58
edboswell
How many fans?
Tuesday, June 27th 2006, 3:37pm
Hi how many fans can the "aquaero 4.00 USB Fan-Controller, VF-Display" handle? - In particular - the airstream 120mm.
Thanks
Ed
Re: How many fans?
Wednesday, June 28th 2006, 1:41am
If I would know how many watt they eat I could tell you.
Each channel on the aquaero 4.00 can handle up to 10W. The maximum of all four channels together should not exceed 30W.
edboswell
Re: How many fans?
Wednesday, June 28th 2006, 2:46am
Ok how many watts does the aqua computer airstream use do you know?
Thanks
Ed
Re: How many fans?
Wednesday, June 28th 2006, 3:05am
Quoted from "Shoggy"
The same like a few minutes ago: I don't know it ;D
edboswell
Re: How many fans?
Wednesday, June 28th 2006, 3:18am
o ok thanks anyway... I guess I will have to wait for Stephan/tests.
Ed
Isaksson
Re: How many fans?
Wednesday, June 28th 2006, 4:51pm
Quoted from "boswell"
Thanks
Ed
The airstream uses 2.16W @ 12 V
If the Data is correct for the airstream in the Shop.
edboswell
Re: How many fans?
Wednesday, June 28th 2006, 6:19pm
:( So I can't quite have 15 fans :(... but then again I need incase fans aswell :(...
Isaksson
Re: How many fans?
Wednesday, June 28th 2006, 6:48pm
Do you realy need 15 fans?
what are you trying to cool?
Re: How many fans?
Wednesday, June 28th 2006, 9:11pm
Sounds like APE1800 ;D
Isaksson
Re: How many fans?
Wednesday, June 28th 2006, 9:25pm
Hehe yeah, thats one hell of a beast, and yes you really needs 15 fans to cool the water in that one ;)
Andreoid
Re: How many fans?
Thursday, June 29th 2006, 3:48pm
and what is with the multiswitch? isn't that a solution? o0
Grüße
André
J_Tuvix
Re: How many fans?
Thursday, June 29th 2006, 7:59pm
if you have got the money for 15+ fans you can also buy a second aquaero  ;D
(maybe an aquaero lite mounted behind the first one)
edboswell
Re: How many fans?
Friday, June 30th 2006, 2:41am
Yes I might buy the lite... can you then have 2 x 30 Watt? - do you have to have an extra power connector attached?
Thanks
Ed
Isaksson
Re: How many fans?
Friday, June 30th 2006, 6:10pm
Boswell.
Is it a APE1800 that you are going to cool?
edboswell
Re: How many fans?
Friday, June 30th 2006, 9:52pm
Yes.
