• 09.10.2026, 11:00
expansion of the airplex series
Thursday, June 8th 2006, 6:46pm
The series of airplex radiators has been expanded. From today you can buy the new pro and xt series besides the old evo series. The new radiators have parallel flat-pipes for a low flow resistance. These radiators also have a black coating and G1/4" windings.
Unlike the evo series the new radiators have M3 windings on the top and bottom.
The lamellae and pipes are made of copper while the casing is made of brass.
Prices:
airplex XT 360: 46.99 Euro
airplex XT 240: 36.99 Euro
airplex XT 120: 29.99 Euro
airplex PRO 360: 36.99 Euro
airplex PRO 240: 29.99 Euro
They are cheaper than the evo series.
Dimensions:
airplex XT 360: 396 x 120 x 45 mm
airplex XT 240: 276 x 120 x 45 mm
airplex XT 120: 156 x 120 x 45 mm
airplex PRO 360: 396 x 120 x 30 mm
airplex PRO 240: 276 x 120 x 30 mm
As you can see the xt and pro series is more compact than the evo series.
A few pictures:
xt 360, pro 360, xt 240, pro 240, xt 120
airplex xt 120
airplex pro 240
airplex xt 240
airplex pro 360
airplex xt 360
additional infos:
The new radiators already have been heavily discussed in the german thread due the fact that they are build by an other company (one of the wolrds largest radiator manufacturer). So don't wonder if you see these radiators at other watercooling companys.
Stephan said the next time there will be a better differentiation because a lot of users weren't happy to see that new xt/pro and old evo series are sailing under the same flag while evo is 100% made in germany and xt/pro are not (the new ones will not have this slogan).
Nitrix
Re: expansion of the airplex series
Thursday, June 8th 2006, 10:24pm
looks great - but will the evo grills fit these rads?
Thursday, June 8th 2006, 11:10pm
Just the new ones. The new ones fits on all our radiators. We have changed the design 2 month ago.
Nitrix
Thursday, June 8th 2006, 11:28pm
cool - is there an easy way to tell the difference?
Also is there any proformance advanage i.e whic is the best for cooling now?
Thursday, June 8th 2006, 11:31pm
The XT-series has the best performance.
Nitrix
Friday, June 9th 2006, 1:33am
How about the 1800 - will there be a replacement for that or a smaller rad inbetween the 360 and the 1800?
Sorry about all the questions :)
Nox
Monday, June 12th 2006, 3:02pm
Does the XT series out-perform the old evo series? If so, by (roughly) how much?
Thanks
TRiXeS
Monday, June 12th 2006, 4:10pm
Quoted from "Stephan"
What do you mean with the new ones? This one wil fit on the PRO 240? http://www.aqua-computer-systeme.de/shop…roducts_id=1088
The screw set, they fit on the new radiators? http://www.aqua-computer-systeme.de/shopsystem/product_info.php?cPath=7_183_185&products_id=1086
jcab
Monday, June 12th 2006, 11:10pm
Quoted from "Nox"
Thanks
Both new radiators (pro and XT) will outperform the evo serie.
The airplex pro is completely equivalent to the black ice pro and the airplex XT is completely equivalent to the black ice extreme. The only difference, is that the black ice radiators are manufactured in Philipines, while the airplex pro and XT are made in China.
uwetr
Friday, June 16th 2006, 7:10pm
Hi jcab
Quoted from "jcab"
do you have any independent sources in the internet for this?
If yes could do me favour and send me a few links per PM?
cheers,
Uwe
A64X2 6000(F3) 3200MHz@CuPlexXT | NVidia8800GTS@AquagraFX8800 | GEIL 2GB Kit@RAMPlex | M2N32-SLI NB@Twinplex, SB@TwinplexXT, SpaWa*2@WaKü | 2*320GB SATA2@Aquadrive DUAL | BeQuiet 470W | LianLi71 EVO360@Deckel| Aquastream/-tube/-injet@-bay | Aquaero | PNC Flow&2*Temp. Sensoren | Multi LED-Modul
Nitrix
Saturday, July 1st 2006, 3:41pm
quick question - how do you tell if you have the new type of grills that will fit the pro/xt radator?
