• 07.10.2026, 12:21
new: aquagrafx 7950GX2
Tuesday, June 27th 2006, 5:18pm
The new aquagrafx 7950GX2 can be ordered now. It's already produced and is currently in the anodizing and engraving process. The block should go into shipment at the end of this week.
The aquagrafx 7950GX2 cools the GPU of both blocks with its dynamic spring mounted core for an optimal heat transfer. The block also cools the RAM, PCIe-switch and the voltage regulators. A thermal pad for the regulators is provided with the block.
After assembly both blocks will be connected via a bridge. It's easy to handle and the o-ring seals ensure that everything is leakproof. The water flows consecutively through both blocks.
The second block (not visible in the picture) is larger and cools the PCIe-switch too.
Price for the aquagrafx 7950GX2 is 119 Euro.
Here is a first picture of a block which hasn't been anodized and graven yet:
And that's how it will look when it is finished:
Nitrix
Re: new: aquagrafx 7950GX2
Wednesday, June 28th 2006, 11:09am
Looks Great - no light up logo this time?
phillyb
Friday, June 30th 2006, 4:57am
Hello, what is the diameter of the fittings? I am using big bore 1/2 inch fittings
Stefan_K.
Friday, June 30th 2006, 1:19pm
Quoted from "phillyb"
We only use G 1/8
phillyb
Friday, June 30th 2006, 10:59pm
what goes G mean? what is it in metrics?
Friday, June 30th 2006, 11:11pm
G stands for the german word "Gewinde" (means screw thread).
outer diameter = 9,73mm
Core diameter = 8,57mm
phillyb
Sunday, July 2nd 2006, 2:13am
Thank you very much for the quick answer.
kaZuo
Sunday, July 2nd 2006, 2:27am
Quoted from "Shoggy"
The "G" stands for Whitworth pipe thread. It is a thread-type like M for metric.
