• 01.10.2026, 20:26
indigo_prime
Plug and Cool or Compression??
Wednesday, July 12th 2006, 5:07pm
I intend on putting together a watercooling system for my new PC. Although it won't get moved around too much, I need to make sure that I get the best type of fitting for the blocks.
Both types of connectors seem really easy to use, but would the compression fittings provide a tighter, more secure fitting than the Plug and Cool?
pharao
Re: Plug and Cool or Compression??
Wednesday, July 12th 2006, 5:50pm
some People had problems of twisted tubes when using compression fittings (=> no waterflow)
some people had problems with leaks when you pull the tubes sideways too hard.
both cases are rare and if you pay attention when you set up your system nothing will go wrong.
I'd recommend P'n'C since it's easier and faster to install.
indigo_prime
Wednesday, July 12th 2006, 6:00pm
Glucklich fur mich das jemand so gut englisch kann. :)
Cheers,
I guess its going to be a coin toss to decide!!
m0bley
Thursday, July 13th 2006, 2:15pm
;D
If you new to watercooling, go for the plug and cool, i have always used these, never had any leaks. Also they look better than the compression fittings.
