• 11.10.2026, 04:06
virtualrain
Insight into Aquaero fan controller workings?
Friday, July 21st 2006, 9:17am
I'm curious, does a fan controller like the Aquaero work simply like a variable potentiometer? Is that the basic principle behind it... providing a voltage across the pins proportional to the "electronic" pot setting?
Is it therefore safe to assume that most fan controllers and the Aquaero could replace the POT on the D5/MCP655 pump that is used to control the speed?
Here's a thread on [H]... http://www.hardforum.com/showthread.php?t=1068890
I may try this mod if folks who understand the Aquaero can confirm that its fan controller can indeed replace the POT on this pump.
Thanks!
Infiltraitor
Re: Insight into Aquaero fan controller workings?
Friday, July 21st 2006, 1:56pm
As the MCP655 has a rating of 24W@12V, and the Aquaero V4 fan channels handle a maximum of 10W, (more than enough for the fans that you're meant to run on them) I'd say no.
The Aquaero is a pretty complex piece of equipment designed to integrate and manage AC hardware and most suitable fans - you're almost certainly not going to receive official support on these forums for trying to run anything else on it. It's also quite an expensive item of hardware to ruin in this way.
Before you ask, I have no affiliation with AC.
Oxize
Friday, July 21st 2006, 5:43pm
Why dont you just take the Aquastream pump? You can control it with the Aquaero. You can manage the flow from 300l/h to 600l/h. Enough for low flow sets like AC.
Ich bin ein Tukker :)
Infiltraitor
Friday, July 21st 2006, 5:56pm
^ Probably because the MCP655 he's looking at can hit 1200 l/h and has 1/2" barb connectors - it's intended for larger bore loops.
virtualrain
Friday, July 21st 2006, 9:09pm
Quoted from "Infiltraitor"
That's correct.  And note, I never proposed controlling the MCP655/D5 pump directly... I know it's power requirements far exceed the output of the Aquaero.
However, the MCP655/D5 pump has a POT which simply acts as a voltage divider to the pump's microcontroller to set the operating speed of the pump.  My question is, a fan controller, like the aquaero is simply a voltage divider as well, right?  It simply provides 0-12V across the appropriate pins.  So regardless of what the fan controller was designed for, the bottom line is it is an electronically controlled POT and can likely therefore be used to replace the manual POT in the MCP655 and thereby control the pump.  The only question to be determined is the voltage range the MCP's POT works over... is it a 12V divider or a 5V divider?
Does this make sense?
Why is there so much resistance here to trying new things? The makers of aquacomputer stuff should be excited to see their goods being used in ways they never considered.
pharao
Friday, July 21st 2006, 9:20pm
Quoted from "virtualrain"
Sorry for this post, ended up quoting myself instead of editing my post above.  Ignore this one.
Again... crap.
lol :)
try this ;)
Saturday, July 22nd 2006, 9:07pm
You can try this. The aquaero will provide you 0.05V to 11.95V. But we are not able to give you any guarante for this. A pot is different to a power source (which the aquaero is). The circuit on the pump can do something really different with the potentiometer.
We will lauch a controller in a few weeks. Maybe this will be your solution.
JaR
Saturday, July 22nd 2006, 10:55pm
Quoted from "Stephan"
"In a few weeks", couldn't you have said that in the laing thread in the german section too?
badger badger badger ...
virtualrain
Sunday, July 23rd 2006, 10:26am
What does this mean?  Can your provide more information?  What kind of pumps will this control?
I'm actually leaning towards the 18W DDC Ultra pump now.  The MCP655/D5 sounds too loud for me.
Thanks!
EDIT:  Actually, I'm going to start a new thread on this since we have diverted subjects... (See thread titled "Using Aquaero to control other pumps")
jcab
Tuesday, July 25th 2006, 6:51pm
I hope that this controller can be connected to the aquaero
