• 23.11.2026, 00:57
indigo_prime
ASUS A8N32SLI
Friday, July 21st 2006, 2:34pm
I'm working forwards on my plan to watercool using aquacomputer components.
My mainboard is the ASUS A8N32SLI and I intend to remove the heatpipe cooler from the mainboard and replace it with water blocks on the NB and SB. I will use the mofset coolers to cool the mofsets near the CPU also.
I have a 7900GTX graphics card and want to know if anyone has been able to use the AquagraFX 7900 GPU cooler with a NB Chipset cooler.
I'd like to use the Twinplex XT for both NB and SB cooling to keep the same look across the system but am not sure if there is enough clearance once the AquagraFX is fitted. If it isnt possible, I guess I'm restricted to the SLI Chipset cooler.
Are there any plans to update the SLI chipset cooler to the same style as the XT NB and CPU blocks?
Nitrix
Re: ASUS A8N32SLI
Friday, July 21st 2006, 10:22pm
I have almost the same board and it will fit fine with the gpu coolers on there.
bender
Re: ASUS A8N32SLI
Wednesday, August 2nd 2006, 10:51pm
here what it's done for me using asus mosfet cooler, twinplex xt and 2 6800gt en sli:
You can grab more pics here: http://www.nokytech.net/forum/showthread.php?t=87965
indigo_prime
Re: ASUS A8N32SLI
Monday, August 7th 2006, 10:06pm
Bender, those are pretty excellent pictures and shows exactly what I needed to see. Many, many thanks.
pharao
Re: ASUS A8N32SLI
Monday, August 7th 2006, 11:17pm
this looks horrible:
or is that only because of the cameraangle?
Nitrix
Re: ASUS A8N32SLI
Monday, August 7th 2006, 11:25pm
its the angle....
bender
Re: ASUS A8N32SLI
Tuesday, August 8th 2006, 1:19pm
yes it's the angle, nothing wrong there ;)
