• 02.10.2026, 03:01
virtualrain
SilentMaxx 500W PSU with water cooling
Wednesday, August 2nd 2006, 9:18pm
Hi, does anyone here own one? Can you please share your experiences?
Also, I see there are a couple of threads in the German forums on this product... could someone who understands German and English please post a summary of user's findings here in English?
Thanks!
virtualrain
Re: SilentMaxx 500W PSU with water cooling
Tuesday, August 8th 2006, 11:21am
Can anyone provide some pointers to some information? Thanks!
JaR
Tuesday, August 8th 2006, 7:40pm
Some people say, it works fine without any fan in the case, others say, that you need a case fan, because the watercooling doesn't really transfer enough heat into the water. There were some problems with unsteady voltages, but that must have been bad luck. What is sure is, that this PSU lacks a few molex connectors (it only has five of those). More details on the connectors:
Quoted
Technische Daten:
Weitbereichseingang 100-255 V AC, 47-63 Hz, 5-2,5 A
+ 12 V: 2x 22 A
+ 5 V: 30 A
+ 3.3 V: 28 A
- 12 V: 0,6 A
+ 5 V Standby: 3 A
Gesamtleistung: 500 W
Alle Kabel mit blauem Geflechtschlauch ummantelt, Steckverbinder:
1x Floppy 4pol.
5x 5 1/4 Zoll 4pol.
2x SATA 5pol.
1x Grafikkarte 6pol.
1x ATX 20/24pol. (teilbarer Stecker)
1x 12V Aux 4/8pol. (teilbarer Stecker)
Anschlüsse: Schlauchverschraubungen für 10/8 mm Außen-/Innendurchmesser vormontiert, G3/8-Gewinde.
badger badger badger ...
virtualrain
Wednesday, August 9th 2006, 4:00am
Thanks JaR, you are very helpful!
Have you come across any tests of its efficiency?
