• 03.10.2026, 06:04
Isaksson
aquagraFX for 6800 Rev. 2
Saturday, August 12th 2006, 2:03pm
Hello.
Iam using a aquagraFX for 6800 Rev. 2 and cooling my gainward 6800 Ultra golden sample edition and iam also cooling the northbridge with a twinplex rev 1.2 the pump is a
aquastream connected to my aquaero and iam using a 2*120 rad to cool the water down.
And now to my problem, the watertemp is 26.8 C but my graficcard is:
GPU: 51
PCB: 38
the flow is 53,5 l/h
i find this very high on the gpu.
I first cool the gpu and then Northbridge.
Babbafett
Re: aquagraFX for 6800 Rev. 2
Saturday, August 12th 2006, 2:46pm
For a GPU its normal
It can be over 70 °C
Isaksson
Saturday, August 12th 2006, 2:55pm
Thanks for the replay.
Yes it can be,
but what i mean is should it be that high with that watertemp and that waterblock
Nitrix
Saturday, August 12th 2006, 4:59pm
I have dual watercooled 7800GTX's on the same loop and there currently at 40C each so it seems a bit high to me - where are you getting the readings from?
Isaksson
Saturday, August 12th 2006, 5:10pm
Hello Nitrix
Iam getting the readings from Gainward EXPERTool, And yes maybe that tempsensor is wrong but i had around this temp with the stockcooler (golden sample).
So even if he doesent show the "right" temp anyway this watersetup does not cool it more that the aircooler.
so thats why i find this strange.
