• 29.09.2026, 23:45
Exie
Linux support
Tuesday, August 15th 2006, 5:11pm
Please forgive me, but I dont know any german. :( I've tried browsing the web site but cant seem to find much information under the "produkte" section.
I currently have a Zalman Reserator1V2, but wish I had brought an Aqua kit. Could I buy an Aqua Computer Aquaero LCD and a sensor module and use it with my current kit ?
Probably more importantly, I run Fedora Core at home, will the Aquasuite software run under Linux ?
... or do I have to have the software ?
I really just want something that will give me temprature, flow rate, alarms and so on.
Katzenfreund
Re: Linux support
Tuesday, August 15th 2006, 5:17pm
First of all you should know, that all the functions you would like to have can be activated and changed without the Aquasuite software.
If you like to use a Linux software, you can find it here:
http://breakbe.at/development/aquaero/
(Sorry, I've a Windows-system and so cann't say anything about the Linux software.)
And yes, it will run.
Just specal things like flow cantroll or pump regulation are probably no possible.
Oh and because you are new: Welcome to the forum.
Re: Linux support
Tuesday, August 15th 2006, 5:31pm
Quoted from "Katzenfreund"
He needs only a flow sensor and the imp/l value can be adjusted directly through the aquaero.
OK, for controlling the pump he will need the aquastream.
I only mention this because it sounds like it would be impossible when he is using linux.
Exie
Re: Linux support
Tuesday, August 15th 2006, 6:09pm
Quoted from "Shoggy"
Fantastic! :) I've found the linux source, and it looks great.
Just before I buy one, can I confirm a twinplex type 3 (24057) will fit Intel 955 northbridge chipset on an ASUS P5WD2 Premium ?
And to confirm when I buy the aquapro (53031) what flow sensor & valve can I buy to go with this ?
Re: Linux support
Tuesday, August 15th 2006, 7:24pm
You can buy a flow sensor from AC.
If you want to get another one it should generate less than 2500 imp/l because that is the maximum value which the aquaero can handle.
