• 06.10.2026, 06:19
virtualrain
Swissflow or Remag flow meters
Tuesday, August 15th 2006, 12:01pm
Hi will either/both of these flow meters work with the Aquaero?
Swissflow SF800 (6100 pulses/l): http://www.swissflow.com/
Remag Vision 2000 (700 pulses/l): http://www.remag.ch/vision.php?language=4&sub=1&tab=2
I recall reading somewhere that the Aquaero has a limit on the pulses per liter that would prohibit it's use with the SF800... is that true? What is the Aquaero limit on pulses/l?
Has anyone purchased either of thse recently? What is the best way to buy one/where?
How has it worked? How much does it impede flow?
Thanks!
Re: Swissflow or Remag flow meters
Tuesday, August 15th 2006, 2:50pm
You can use the remag flow meter.
A value of 700 imp/l is no problem for the aquaero.
2500 imp/l is the maximum which the aquaero can handle.
virtualrain
Tuesday, August 15th 2006, 8:36pm
Quoted from "Shoggy"
Thanks!
Has anyone here used this flow meter?
heed
Saturday, August 19th 2006, 7:26pm
Don't mean to threadjack but I had a question along these lines: what would happen if I did hook up a Swissflow meter to the aquaero? I just bought one, and really only want to know whether there is flow or not, don't care much about actual amount. Does anyone know?
