• 22.11.2026, 22:50
Dementia
AquagraFX6800LE Compatibility with BFG 7900GT OC
Sunday, May 21st 2006, 8:13am
According to: http://www.kustompcs.co.uk/acatalog/info_7814.html
this water block is not compatible with the BFG 7900GT OC: "Note : Not compatible with BFG OC graphics cards". This appears to be the only place that mentions comptibility with this card, which, as far as I can see follows the reference design exactly. As such this is currently putting me off buying ANY waterblock for my card, after all if one block has trouble with just my card so could any other.
Any official word on this? Is there a problem with the BFG 7900GT OC, and if so any ideas exactly what it is so I can work out if other blocks will fit. Thanks, Nick.
Nox
Re: AquagraFX6800LE Compatibility with BFG 7900GT
Thursday, June 8th 2006, 12:25pm
I have that GFX card, and that block. Its not actually fitted yet though - we got notice we were moving the day it arrived so its all packed away at the moment - I'll be able to tell you in about a month
Nox
maxtor
Re:AquagraFX6800LE Compatibility with BFG 7900GTOC
Thursday, July 6th 2006, 7:18pm
I sent this question in a mail to AquaComputer.
"My graphics card is an BFG GEFORCE 7900GT 256MB OC DVI HDTV PCI-E, i have read that your cooler aquagrafx 7800/7900 GT wont work with my card.
Can you please deny or verify that."
This is their reply
"Hi,
yes that's right. The 7900 gt waterblock is not adapted to to your graphiccard.
Thank you and best regards,
Kevin Förstermann"
So it will not work  :(
azn_bboy07
Thursday, July 20th 2006, 10:13pm
damn, i already purchased that block for my rig, even i'm running 7800gt but its a sad news to hear that it wont compatable with 7900gt series. Or will it fit to any other 7900gt? or jsut bfg?? and other question wud it fit on 7900gtx??
cheers
Nox
Tuesday, September 12th 2006, 3:40am
Well, i've just fitted my rev 2 6800LE block to my BFG 7900GT - looks like its fine... didn't have to shave anything off anywhere on it.
Guess i'll be finding out in the near future though!!
Nox
