• 11.11.2026, 19:10
Nitrix
Aquero issue
Thursday, September 14th 2006, 8:02pm
E-mail from a customer please can you shed some light on this:
I've got conection problems with my Aquaero 4.00, recently installed in a G70 (by yourselves as it was a pre-installed unit). The USB header is working perfectly well on my board (Asus P5W DH), but the connection to the Aquaero is very temperamental and almost non-existant. I have managed to connect to the controller just twice in 5 hours of diagnosis. I managed to set the fans on my triple rad to run at 50% of their total speed, and saved to the firmware, I then restarted and I lose the connection. In my Device Manager it is seen as either a "Generic USB Hub" or a "USB Human Interface Device" when it has worked - it is never recognized as the Aquaero 4.00 which I find odd. But now it is not recognising at all.
Can you tell me exactly how the USB cable should connect to this motherboard please just to iron out the seed of doubt in my mind? I have connected the other end correctly to the Aquaero itself using the instruction manual.
Nitrix
Re: Aquero issue
Thursday, September 14th 2006, 8:59pm
FIXED
A_L
Re: Aquero issue
Tuesday, October 10th 2006, 3:26pm
I'm having another question at the ATX POWER CONNECTOR to Aquaero. ( I also connected the RELAY / 5V power to Aquaero ).
I used it with my PSU & Aquaero fine, but when I swtich off the PC, the Aquaero's VFD & LEDs connected to it keep constant ON!
Is it ok for VFD display & LED keep lighten-up all the way??
Or my situation were not normal?
A_L
Re: Aquero issue
Tuesday, October 10th 2006, 8:15pm
Sorry for I had made a mistake.
1) The LEDs does off after PC shut-down.
2) Any possible to let Aquaero working with-out VFD display after PC shut-down? Because this PC were located in bedroom.
Thanks,
Andy
SNIFFER
Re: Aquero issue
Thursday, October 12th 2006, 8:51pm
It will stay live till you depower your PSU, it you have a switch on your PSU you can switch it off there. Or failing that you can switch it off at the mains plug.
I have the same problem with an IMon display, it stays live after shutdown. I imagine the same thing will happen with your Aquaero as your powering it now via the 5v Standby line, thats why its a standby line after all.
SNIFFY
J-C
Re: Aquero issue
Sunday, October 15th 2006, 12:04am
Quoted from "Nitrix"
I have same problems, how do you fix it? Please
Re: Aquero issue
Sunday, October 15th 2006, 1:29am
Quoted from "J-C"
Have you installed the newest BIOS Version? If a Beta version is avaialable, try this too.
Asus boards are known for their problems with the aquaero. The most users were able to solve the problems with a BIOS update.
