• 17.10.2026, 16:03
zifnab26
connectors help
Wednesday, November 29th 2006, 10:44pm
Hi all complete newbie here ;D. I've just got a kit that uses 3/8 tubing and i want to get the cooling block for my 7900gtx and i was wondering what connectors i'll need so i can fit it.
Infiltraitor
Re: connectors help
Wednesday, November 29th 2006, 11:30pm
Hey there,
If you're planning to use 3/8" ID tubing, I'm assuming that you'll be going with barbs rather than pushfit fittings?
If so, these would be the fittings you're after.
Can I ask what other watercooling gear you're planning to use in your loop?
zifnab26
Re: connectors help
Friday, December 1st 2006, 1:49am
Thanks for the reply
I've got a termaltake armor - so right now i've just got the pump, resivoir, radiator and cpu block. I've just bought my 7900gtx and i want to get it hooked up asap so i can OC it :)
