• 12.11.2026, 22:23
7HUND3R
that block for CPU AMDX2 4200?
Sunday, January 21st 2007, 5:33pm
hello to all, I to liked much as much am new in the forum and the Web as the store online, pleases me to aquacomputer by its design of pieces for the refrigeration eliminates like for modding, I am very enthusiastic to this. good here my doubts. as computer I have this:
CPU amd atlhon x2 4200
motherboard asus a8r32 MPV deluxe
2x dual kingtom k 512 chanel
it wanted that you advised to me of a water block for this CPU. I think to do overclock to the CPU reason why it wanted a block CPU that I cooled well. as water pump I put aquastream 12v rev 3,5 and it mounts it with tube of 8 mm and racores plug&cool for tube of 8. not if this coarse pump dara to cooling so many components the ram memory and the CPU so that chipset does not warm up (radeon express 3200) the radiator is thermaltake of 12cm at least aluminum. thank you very much.
Re: that block for CPU AMDX2 4200?
Sunday, January 21st 2007, 7:05pm
Welcome to the forum :)
You can buy any CPU-cooler from aqua computer. With the right mount they all will fit on your board. The difference in performance between all blocks is rather small (around 1-3°C).
A performance chart would look like that:
1.) cuplex xt
2.) cuplex pro
3.) cuplex evo
5.) cuplex 1.3
As you can see, the cuplex pro has the best price-performance ratio.
By the way: your english is very weird. Looks like your are using a translator like google or bablefish ;D
7HUND3R
Sunday, January 21st 2007, 9:35pm
I to be using translator of google. that this translator to be translated, I badly to try to write a way easy so that translator google not to translate badly. thank you very much by aid, I like cuplex XT by design. this to have adtactador for 939 or to have to buy aside?
Sunday, January 21st 2007, 10:14pm
You need that version.
Please note that you have to buy the connectors separately.
The mounting can be exchanged every time for new sockets.
7HUND3R
Monday, January 22nd 2007, 10:59pm
;) ok. thanks
when I can plows an order of this block for CPU and ramplex and aquajet for I deposit aquatube to facilitate the filling of the circuit. thank you very much.
