• 06.10.2026, 14:59
d3daim
AC Flow Meter..flow rates?
Monday, January 15th 2007, 8:25pm
I have the AC Flow Meter and I will be using 1/2" barbs with G1/4 BSPP threading. I just took a look inside the opening of the flow meter to see that it narrows DRASTICALLY.
Wouldn't this have a terrible impact on my flow rate when included in my loop?
-d3d
Nitrix
Re: AC Flow Meter..flow rates?
Monday, January 15th 2007, 8:33pm
Probably if you are using a high flow 1/2" system as the flowmeter was designed to be used on a system that does not need "high flow" in order to work.
d3daim
Monday, January 15th 2007, 9:11pm
right..so the sensor
http://www.sharkacomputers.com/aqcoflcoseca.html
would probably be a bad to include in my loop. Damn.
edboswell
Monday, January 15th 2007, 11:17pm
well not necessarily... if you have the time.. i would check the temps of when you have the sensor.. and when you don't have the sensor... if they are a big difference then scrap the sensor.. but in my honest opinion.. I don't think the flow makes that much of a difference (especially if you have aqua computer blocks).
Ed
d3daim
Monday, January 15th 2007, 11:35pm
Alright, I'll keep that in mind. Thanks.
Infiltraitor
Tuesday, January 16th 2007, 12:32am
What blocks are you planning to use?
d3daim
Tuesday, January 16th 2007, 1:36am
I'm using a DangerDen Maze4 gpu block and a Swiftech Apogee cpu block.
Infiltraitor
Tuesday, January 16th 2007, 9:14pm
I'd look for another flowmeter then - the AC one isn't suited to your loop.
d3daim
Wednesday, January 17th 2007, 1:59am
Great, I appreciate it.
I just figured the AC flowmeter would be my only choice because I need the specialized output designed for an Aquaero.
d3daim
Sunday, January 28th 2007, 11:05am
You find any alternatives? Should I try to enlarge the flow meter hole?
I'm familiar with drill/tapping, I did it for the aquatube for 1/2" fittings..
