• 29.09.2026, 21:04
mcr
Question about coolant
Friday, February 2nd 2007, 9:56pm
Hello
I was wondering how to get a effect like these following photo's.
http://www.casecon.de/blackdeath/lianli36.jpg
http://www.shoggy.de/ac_forum/case06_innen3_g.jpg
do you use some special hoses or a special fluid?
also.
i have the same cpu cooler as on the picture of this picture:
but i used some wrong coolant. i just used distilled water and now after a few months it has some algen in it.
can i remove those or is it better to buy a new cooler.
i tried to open the cooler but i dont have the right size screwdriver for it, does anyone know what size it is ?.
Best regards.
you know my steez...
Infiltraitor
Re: Question about coolant
Friday, February 2nd 2007, 10:05pm
You can use either UV reactive coolant additive (AC's BlueMotion or ClearMotion for a blue glow or GlowMotion for a green glow) or UV reactive tubing (Blue reactive P&C tubing) which is probably the easiest method of achieving a nice even glow.
mcr
Saturday, February 3rd 2007, 8:33pm
so i take it that this :
Tubing PUR active blue plug&cool
that this ISNT a blue hose, but just a blue UV, because i dont want a blue hose.
it says also plug&cool but i just use screw fittings.
maybe shoggy can help me out on this one ;)
Katzenfreund
Sunday, February 4th 2007, 8:28am
First of all it would a good idea to rinse your cooler as long as there are algen in it.
Secondly: Use ACFluid in future, this should prevent further trouble with algen.
And yes - as far as I know - Shoggy is using the tubing in activ blue uv.
And yes, AC doen't sell it for other fittings then for Plug and Cool.
Does that help a bit?
mcr
Sunday, February 4th 2007, 1:09pm
yeah, but what do you mean with rinse your cooler?
i am using innovatek protect right now wich is anti algen.
so i cant use the hose with 8/10 screw fittings?
thats a pity ;(
Katzenfreund
Sunday, February 4th 2007, 1:24pm
Quoted from "mcr"
Didn't you say, you've got algen in your cooler?
mcr
Sunday, February 4th 2007, 2:50pm
yeah i did, but what does rinse mean?
Katzenfreund
Sunday, February 4th 2007, 4:22pm
ohh. I'm not quiet sure if this is the right expression.
But I wanted to say something like:
Demount the cooler and clean it with clear water. Do this as long as you can see algen in your cooler.
Except of the CuPlex Evo, you can even remove the glas of the cooler and lay it in citric acit for some minutes, to clean it.
