• 22.11.2026, 22:04
new and available: aquagratix R600
Monday, May 14th 2007, 6:56pm
On schedule to the release of the Radeon 2900 XT there is also the suitable cooling block from Aqua Computer available and at the store .
Of course the aquagratix R600 has the patent protected core pro System which excellently cools the R600 GPU of the card and its spring mounted core prevents damages and assembly faults.
All relevant components are cooled. So the RAMs, the voltage regulator and the GPU. At the development of the cooler the flow resistance was reduced to a minimum. The main channels have an area of 10x6mm!
Moreover, the weight was kept very low and below the ATI cooler.
For an optimal assembly spacers were integrated into the cooler. The original Backplate of the GPU is continued to use.
Like all other hig-end coolers that one has an integrated red illumination too.
Here a few photos:
Nitrix
Re: new and available: aquagratix R600
Monday, May 14th 2007, 10:38pm
Wow thats a mad design ;)
