• 19.11.2026, 18:07
guy59
noise of aquastream
Sunday, May 13th 2007, 1:15pm
hi,
I have a sound problem of harmful effect with my aquastream. Indeed, it makes an unpleasant noise of “buzz”. I carried out a support “sandwich” to eliminate the vibrations and Ca does not come from there. I also modified the propeller and there is no more “play”. I can also specify that I do not think of having bubbles of air “to have shaken” the PC well and to leave the pump in deaeration mode during more than one hour. For information, on Aquasuite, the pump is with 8w and I wonder whether it is not too high knowing that I could read on various handbooks which the normal power is towards 4,5 w.Qu' think about it you? thank you
Nitrix
Re: noise of aquastream
Sunday, May 13th 2007, 4:45pm
tbh the easiest thing to do is replace it we seem to have had a bad batch that have been noisy :(
guy59
Sunday, May 13th 2007, 7:08pm
I did not understand well, that must I replace: the pump (aquastream) ?
Nitrix
Monday, May 14th 2007, 1:47am
yeh you probably have a faulty pump
mario_cell
Tuesday, May 15th 2007, 4:46pm
call the support of AC and they will help u :D
Like nitrix said, u probably got a bad pump :P
guy59
Tuesday, May 15th 2007, 8:22pm
Quoted from "mario_cell"
guy59
Tuesday, May 15th 2007, 8:26pm
Thank's for your answare
I noticed that the noise in question was very attenuated lorque I increase the frequency of the pump. In fact, it makes this noise only when I regulate the frequency by defect
