• 11.10.2026, 13:05
new: aquaduct - the external solution
Tuesday, December 19th 2006, 12:50am
Punctually to the end of the year we owe you a few new produtcs. A long time ago we presented yout the hypersis - it got a lot of attention but was never mass-produced. We found a lot of things not good enough.
Of course we continued the development. What came out is the new aquaduct series: an uncompromising solution. We wanted a convincing design and a cooling performance which sets standards at a minimum noise level. All of that was reached with the aquaduct series. It is foolproof to handle, secure and compact.
It got the name, since the water runs over a kind of bridge at the top and falls down then on the other side.
The aquaduct is a combination of passive and active radiator whereby both variants can match the required cooling performance.
To the series start at the beginning of January, you can choose from two variants. The entry modell contains a 230V pump with a dual radiator. The top modell is the aquaduct XT. It unites our experiences and developments of the last years. It offers all features of the aquaero in an adapted controller; measuring of flow rate, thermal control of all important functions, fan control and an USB connection for the aquasuite - of course network-compatible. The vario-light function (temperature-sensitive with alarm) was directly integrated. The aquasuite (a new, strongly revised version) will graphically completely display the aquaduct.
To keep the maintenance of aquaduct as low as possible, large water tanks were integrated into the cooling profiles. Through this the refill of water minimizes itself to an annual maintenance. Two ball valves were integrated at the bottom and allows you to disconnect the aquaduct without draining the system. Their advantage are better flow rates while self-closing couplers are more restrictive.
Apart from electronic monitoring, two small balls in separate pipes show the function of the aquaduct. A black ball shows the fill level while a red ball shows the flow.
The aquaduct comes with a small platine for the PCI slot. It supplies the aquaduct with current and offers monitoring-functions. A potential-free output allows the aquaduct to shutdown the PC in case of an error or problem. Jumpers allow the control over the voltage for the fans (version without aquaero).
The aquaduct will be ready within the next days. As a special christmas offer it will cost 229 Euro / 369 Euro - only for a very short period of time.
And now some photos:
The logo  ;)
Dthe "small" aquaduct 240
and from behind
The aquaduct 360 XT from above with its integrated lighting - unfortunately without flowing water.
and here the front
The fill level indicator (all versions have it)
The bottom
The back side
Ball valves and connectors
The PCI card
The aquasuite (BETA). All arrows etc. are animated, can change color, angle, size and so on. It is possible to calculate operating parameters, for example the maximum performance or load.
Nitrix
Re: new: aquaduct - the external solution
Tuesday, December 19th 2006, 1:13am
That is VERY Nice!
there are alot of neat features there - is the main plexi bit on the top a res aswell or just a window?
Also is the unit totally powered from the pc or is there an external power source needed to?
melon
Tuesday, December 19th 2006, 4:56am
Quoted from "Nitrix"
That is VERY Nice!
The Plexi is the "Fillport" for the two big res. which are in the two Silver Aluminium Profiles. The Profiles also have a Level-meter.
Quoted
The "small" Aquaduct uses two Powersources
1. 9-Pin Sub-D for the Fan's
2. 230/110(??)V for the Pump
The USB-Port is only a dummy, because there is no Aquaero included.
Take a look at the upper left corner. ;)
The Auquaduct XT uses the 9-Pin Sub-D only, USB for Datatransfer.
Another nice Feature:
On one side there is the Black acrylic Ball -> Level-meter.
in the other Aluminium Profile u have a Red Ball -> Flow-meter. 8)
(Ps: man kan über treiben)
m0bley
Tuesday, December 19th 2006, 5:46pm
Thats looks wicked 8)
m0bley
Wednesday, December 20th 2006, 2:03pm
Hi there, put me down for a pre-order of the aquaduct 360 XT
Cheers ::)
Wednesday, December 20th 2006, 4:08pm
Maybe interesting ;)
The aquaduct is using the airplex pro radiators with airstream fans. The pump is a modified version of the Eheim Compact 600. The flow in standard mode is around 80l/h. Like the aquastream you can "overclock" the pump for a higher flow rate.
Within the case you will find only one tube for the radiator. Everything else is directly integrated to the bottom plate. All electonic parts are using pluggable cables. In case of a fault you can easily exchange the damaged part(s).
SNIFFER
Tuesday, December 26th 2006, 5:44pm
Lovely peice of kit. Certainly beats my attempt at an outside radiator box. Might have to consider getting one, would it be ok to have both the pump in the Aquaduct and the normal Aquastream pump running together in series. Could that cause any problems?
Wish this was avaliable last year, could of saved me hours of time making my Radbox:
El_Perro
Friday, April 20th 2007, 6:40am
Quoted from "Whyn8s-Shoggy"
Shoggy,
I just purchased and installed the aquaduct 360XT. It's beautiful! :o but.... what exactly do i have to do to overclock the pump???
Thanks!
Ben
Friday, April 20th 2007, 8:46am
Quoted from "El_Perro"
Shoggy,
Thanks!
Ben
Go to the compactstream Pump Menu with the buttons (aquaero) oder install the aquasuite software (Tab compactstream) and set a higher frequence.
Sebastian
El_Perro
Friday, April 20th 2007, 4:34pm
Quoted from "Sebastian"
Sebastian
Thanks for the resp0nse sebastian...I have the aquasuite software installed and I have gone into the compactstream tab, but the highest I'm able to set it is 74Hz (that i know of)..which yields about 88 l/h ..
was hoping i could somehow make it pump a little faster..
pharao
Friday, April 20th 2007, 5:07pm
what for? it will only get louder and your system won't get any cooler.
depending on what type of cooler you have, waterflow is irrelevant (as long as it stays above 22-25 l/h)
El_Perro
Saturday, April 21st 2007, 3:14am
was hoping I could experiment with it.
Is there a way I can overclock the pump beyond 74Hz?
Thanks guys
Saturday, April 21st 2007, 10:28am
Thanks guys
no ;).
El_Perro
Saturday, April 21st 2007, 5:38pm
Ok. fair enough. However, I thought otherwise when I saw the specifications for the 360XT at Sharka Computers:
Specifications:
Radiator: Airplex Pro 360 Triple 120mm
Core: 2 Pass Copper
Cooling Rate: 1732 KCal/hr
Passive Cooling: Aluminum Side Channels
Pump: Eheim 1001
Output: 150 - 600 l/h (39 - 158 gph)
Power Consumption: 11W
I will say again what a fine piece of craftsmanship the 360XT is.....and, I've got an Intel Quad Core system at 3.6GHz/1800MHz-FSB with 48celcius(idle) and 56celcius(load). wOw! Great job guys.
Saturday, April 21st 2007, 7:57pm
The pump specifications are measured (by Eheim) without any resistance.
El_Perro
Saturday, April 21st 2007, 9:20pm
Quoted from "Shoggy"
I see; thanks.
El_Perro
Thursday, May 17th 2007, 10:28pm
hi guys. how often should I put my aquaduct in 'deaeration mode'? and how long should i keep it in that mode?
thanks
Thursday, May 17th 2007, 10:35pm
If you don't have any problems it is not necessary to run the aquaduct in deaeration mode.
