• 22.11.2026, 22:59
aquasuite 4.43.00 + Firmware 4.11 + Setclock 1.1
Wednesday, May 23rd 2007, 5:13pm
There are some updates of the firmware and software.
aquasuite:
- warning message if you try to flash an aquaduct firmware on an aquaero or vice versa.
- the tubemeter symbol appears in the right color palette now.
- a few small corrections.
auqaero and aquaduct firmware 4.11a:
- the temperature controllers work now without faults if the minimum level is set to 0°C.
- the LEDs do not flash any more if two sensors are used for the automatic light control.
SetClock 1.1
- is running under Vista x64 without any problems now.
Known problems:
The aquasuite runs on Vista 64 only with administrator rights if it was started from the normal program folder. Installing the aquasuite into the "own files" works without that problem.
DOWNLOAD aquasuite 4.43.00
DOWNLOAD SetAquaeroClock 1.1
Have fun with the software.
Top_Nurse
Re: aquasuite 4.43.00 + Firmware 4.11 + Setclock 1
Friday, May 25th 2007, 9:15am
Is there anyway to exclude any of the unused items from the overview page? Like unused fans, sensors, etc.
