• 22.11.2026, 23:27
fr4nk
High CFM fans with aquaero ?
Thursday, June 7th 2007, 3:29pm
I plan on using some high powered fans (3 of them) with my aquaero, will it be okay or will it kill the fan controller on the aquaero ?
The fans I plan on using: http://www.scan.co.uk/Products/ProductIn…roductID=590758
Thanks
-Fr4nk
Top_Nurse
Re: High CFM fans with aquaero ?
Thursday, June 7th 2007, 5:50pm
Depends...
The link you provided does not show the required information in power consumption (watts). The new version 4 hardware can take up to 10 watts per channel with a total max of 30 watts, IIRC. The version 3 hardware is limited to 5 watts per channel.
fr4nk
Thursday, June 7th 2007, 9:27pm
I found out that it uses 3.60w, from a french web shop so either it should be fine :)
http://www.google.com/translate?u=http%3…n&hl=en&ie=UTF8
