• 22.11.2026, 21:18
johnnytsunami
Aquasuite doubt.
Thursday, June 21st 2007, 6:18am
Hi i just installed the new version of aquasuite under windows vista and when i open it, it doesn't show anything. It just displays the upper menu and the background(aquacomputer aquasuite).
Re: Aquasuite doubt.
Thursday, June 21st 2007, 2:34pm
Make sure that your aquaero, tubemeter, multiswitch or whatever you have is connected the right way.
SNIFFER
Monday, June 25th 2007, 2:43am
Yes make sure you have connected your USB cables correctly, it is quite easy to believe you have done so. It works fine on my Vista PC.
edboswell
Monday, June 25th 2007, 3:01pm
I had the same problem... as sniffer said.. its quite easy to believe you have... when you actually havn't :P
