• 06.10.2026, 15:36
taranatar
Aquaduct 360XT help please
Saturday, August 4th 2007, 2:06pm
thinking of buying one of these or the 240 version, first of all this will be my first cooling set up. its too cool a e6600 will these be ok?
also these dont come with a water block so its ok to pick anyone? what size waterblock do i need to get, as in what tubing does the aquaducts use? i wanted to get a swiftech gtx block or anything esle someone recommends.
also whats the perfomance like, ive been looking at external kits for my first try into water cooling. and alot of external kits get bad reviews so really what are the aquaducts like?
thanks for the help guys
gr3if
Re: Aquaduct 360XT help please
Saturday, August 4th 2007, 4:08pm
The Aquaduct is a 240 Radiator so every inside build kit will have the same Temps. Cooling a e6600 is wonderfull. The Aquaduct uses 1/8 Tube so u need 1/8 plugs for the coolers, as long as this tubing fits u can use any Block u would like to and yes the Aquaduct comes without Cooler at all.
taranatar
Saturday, August 4th 2007, 4:35pm
thankyou for getting back to me,
1/8 tubes? how do i get any waterblock for this? all blocks i see are 1/2 or 3/8 please help!
Stefan_K.
Saturday, August 4th 2007, 6:50pm
Just buy yourself the aquaduct and get fittings for your choice of tubing. Size is G 1/8"
Quoted from "gr3if"
And temps are better than a radiator build inside a case. fresh air all the time. ;)
Top_Nurse
Sunday, August 5th 2007, 1:00am
G 1/8 is the pipe size and not the internal diameter of the tubing. The outgoing connectors can utilize 6mm (1/4"), 8mm (5/16"), or 10mm (3/8") fittings. However the kit comes with 6mm ID tubing.
The Aquaduct 240 and Aquaduct 240 Pro both have a 240 size radiator in it. The Aquaduct 360 XT has a 360 size radiator in it. The 240 sized Aquaduct's will be fine, but if you want some room for additional blocks you should consider the 360 XT.
If you want to see the 360 XT opened up, you can go to this thread. ;)
