• 22.11.2026, 23:42
MDHellDK
temp sensors for aquaero
Friday, August 10th 2007, 2:36pm
Hi all,
i'm a newbie in WC and have just bought:
Cuplex XT di CPU cooler
Twinplex XT chipset cooler
aquagraFX for 8800 GTS with core pro
high end 360 kit
aquaero 4,00
I have searched high and low for some pictures and or some explainations for where to mount the temp sensors... i know where they fit on the aquaero but where does the other end go???
MDHellDK
edboswell
Re: temp sensors for aquaero
Friday, August 10th 2007, 9:32pm
wherever you want:)... I would get the water temp conversion thingy so you can see how hot or cold the water is.
Then you could have one just outside the case... one inside the case...one selotaped to a hard drive....just a few ideas..
MDHellDK
Friday, August 10th 2007, 11:39pm
thx for your reply ;D
which water temp conversion thingy ??? ;)
I thought that the temp senors were for measuring core temperature on the CPU, GPU and chipset, so that the fan would adapt speed for high low cooling :o
MDHellDK
gr3if
Saturday, August 11th 2007, 3:55am
Not really the Sensors are there to measure temperature at any point u would like them to so u can plug one on your cpu cooler aside the thing that touches your cpu
to measure water temp use something like this:
http://www.aqua-computer-systeme.de/shop…9d418248a15ac91
MDHellDK
Saturday, August 11th 2007, 3:00pm
thx for reply, i will return when i have put the pc back together again :D
